I have a Sony KP-46S17 that you hear it clicking on but then shuts right off. The LED in the front blinks and that is all it does. If Someone can help it would be greatly aperciated thanks. The model number i get off the back i can't find it anywhere. They say invalid model number so I don't know why when its on the back of the unit.
How many times does it blink?
Check the two 0.47 Ohms safety resistors (R8895 and R8896) in
the +135V line on the D-board are open and transistor Q8804 is
shortened between collector and emitter.
In that case, flyback
transformer T8800 will be the root cause and in 95% of the cases only
replacement of these four components will fix the problem.
it blinks four times and shuts off
i have the exact same problem, the only difference is that my red light flashes 8 times,stops flashing for about 2-3 seconds and then the flashing sequence begins again
blinking 8 times - high voltage fault?? D-Board issue? Easy DIY fix? I'm mechanically illiterate.
KP-46WT500 - TV will turn on, turn reddish, then turn off and blinks 8 times.
I have the exact same televison/problem. I turn it on, it begins to warm up and then shuts off. blinks 10 times, stops and repeats sequence. Hit power again, repeats process, only this time blinks 5 times and then stops and repeats. Hit power 3rd time and it turns on and is fine. If it is on and I shut it off and turn it right back on, it is fine. The problem only happens when it has been off for 1/2 hour or more. PLEASE HELP as I love/need my televison and can not afford a new one right now. Sony customer service is ****. I have always been a Sony fan, but after this tv of only 4 years does this out of the blue and customer service is ****, i will not buy Sony products again!
