SOURCE: have a toshiba 40rv525r HD LCD tv, turned it on
Looks like video problem. Contact authorized service center.
SOURCE: Toshiba 40rv525r screen says NOT AVAILABLE
I've had the same issue! This is caused by the control panel telling the TV what to do - does it change channels on its own, too, or turn off or on on its own?
What you need to do (if you've not already done it) is lock the control panel out, which you can do under the LOCK menu.
What may help is running the factory reset on page 54.
SOURCE: toshiba 40rv525r LCD t.v. have sound but turned
Sorry, I donʻt have solution, but I do have this exact same problem, same model of TV! Iʻm wondering if youʻve had it fixed yet and if so, how did you do it?
SOURCE: FUSE KEEPS BLOWING ON MY TOSHIBA MODEL 26AV502U TV
The power supply board have trouble with it many power supply transformers.That why u getting to must current and keep killing the fuse.U have electronic skills and troubleshooting skills check all those input and output of those power supply tranformers coils,replaced the wright dead tranformer,will solved this problems.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Testimonial: "thank you for your responce"
