Question about Toshiba 57H81 57" Rear Projection Television
SOURCE: Toshiba 42H83
Most projects in life are "easy",if you know how.Chassis will have to be pulled,convergence IC's replaced w/top quality parts to prevent recall.Some excellant soldering will be needed for prevent maintenance,for instance,the steel jumper wires feedig b+ to convergence IC's. RE-align in servicer mode==final step.
Posted on Sep 29, 2007
SOURCE: control board say not availible when any button is
this may be due to a stuck on mode select button control, are you going to try to repair yourself ? do you have a shop manual ? let me know
Posted on Jan 31, 2010
SOURCE: My toshiba 42h83 tv has sound but no picture
of course check different inputs etc to make sure something did not get disconnected.
This rear projection set uses 3 picture tubes and the set will protect them if there is a problem in the vertical or horizontal sweep circuits that might burn the screens or the damage the tubes.
No simple answer as a lot of different parts are possible for this problem.
Posted on Apr 28, 2012
Testimonial: "much better thank you"
Apr 27, 2012 | Toshiba 42H83 42" Rear Projection...
Oct 22, 2010 | Toshiba 42H83 42" Rear Projection...
Jan 30, 2010 | Toshiba 42H83 42" Rear Projection...
Oct 27, 2009 | Toshiba 42H83 42" Rear Projection...
Oct 21, 2009 | Toshiba 42H83 42" Rear Projection...
Aug 16, 2009 | Toshiba 42H83 42" Rear Projection...
Feb 01, 2009 | Toshiba 42H83 42" Rear Projection...
Aug 09, 2008 | Toshiba 42H83 42" Rear Projection...
Sep 10, 2007 | Toshiba 42H83 42" Rear Projection...
Aug 03, 2007 | Toshiba 42H83 42" Rear Projection...
Feb 12, 2014 | Toshiba 57H81 57" Rear Projection...
70 people viewed this question
