Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
SOURCE: freezer drawer handle loose...how do I tighten screws?
With a screwdriver?
Screws in plastic will wear with constant use , take the screw right out and wrap it with aluminium foil, then replace
Posted on Jan 24, 2008
SOURCE: the handle on the bottom freezer drawer is loose
Sometimes the studs that the handle mounts to become loose themselves. If you remove the handle entirely and look at the studs, they will have either a phillips head or they will be hex-headed so you can tighten them. Carefully snug the studs down (do not over-tighten) and re-install the handle. This should solve your problem.
Let me know if you need more help
good luck
Posted on Aug 11, 2010
