KitchenAid KGST307 Gas Kitchen Range Logo
A
Anonymous Posted on May 25, 2014
Why does the cook top burners click one time and do not light
Wzystko Cokham
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jun 30, 2014
Wzystko Cokham
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
1304
Points
8
Because "It" doesn't Like You! LOL OK really you have a bad Ignitor. It is the device that makes that "Clicking" sound. Though rare, they do fail. So you can replace it.
3helpful
JGBS20BEW2AD, the stove top four cooking burner constantly clicks.
The igniter switch(s) has most likely failed shorted. Fairly common with gas ranges with spark ignition.
3helpful
Hello - I ran out of propane - How do I light the ignition?
Your range is electric ignition and should not require any relighting. There may be air in the line and can be purged at the cook top burners. Just turn the burner knob on until it starts clicking and let it click until the burner ignites. The oven and broiler will then light normally.
Clicking on stove top will not stop
Unplug the stove top for a few days, and let the burner switches dry out. Sometimes this is caused by moisture getting into the switches from a boil over, or from someone cleaning the stove top. If your unit still sparks after a few days then you will have to replace the bad burner switch, or switches. I am assuming that you are talking about a cook top that is sparking all the time, and not about a cooktop that is sparking, even after the burner lights. If your burner is still sparking after it lights, you usually have a bad spark module. Good Luck, Appliance Specialists
Burners on top will not light with the pilot lights
To Clean:
IMPORTANT:
Before cleaning, make sure all controls are off and
the oven and cooktop are cool. Do not use oven cleaners, bleach
or rust removers.
1. Remove the burner cap from the burner base and clean
according to “General Cleaning” section.
2. Clean the gas tube opening with a damp cloth.
3. Clean clogged burner ports with a straight pin as shown. Do
not enlarge or distort the port. Do not use a wooden
toothpick. If the burner needs to be adjusted, contact a
trained repair specialist.
4. Replace the burner cap, making sure the alignment pins are
properly aligned with the burner cap.
5. Turn on the burner. If the burner does not light, check cap aligment.
1helpful
2answers
Cook top will not light
Try to light it with a match to verify gas is getting to the burner.
If it light with a match you will have to repair the ignitor for that burner.
Gas burners lit, but electronic ignition still clicks
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
fsggfs
Top burners often wont light if oven is already lit
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
1helpful
3answers
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
1helpful
Kitchen aid cook top gas. iginator consstantly firing with knoob off
strutz, you probabley got one of the valve switches wet when cleaning. It could of shorted out or it might be just wet. Pull the control knobs off the burners and take a hair dryer and go over the valves slowly. See if it stops the clicking. If not you will probabley have to change out one of the switches. Im not coming up with anything with the RGA365 model number. Try the above posted first...Catriver..post back.
Top KitchenAid Kitchen Ranges Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
