Question about Samsung Digimax S500 Digital Camera
Memory Card Locked
I went this afternoon to develop pictures from my memory card and downloaded them to my PC tonight. Now when I try to take new pictures or delete those I've already printed and copied to my PC I get a message that the card is locked.
Posted by irishred on
  • 1 more comment
  • brumbar4e Nov 20, 2007
    I have the same problem :( It shows a message - "Card locked", even when the plastic thing is down....?? Do you have any idea why, I tried everything :(
  • Anonymous May 22, 2008
    WHERE IS THE CARD LOCK SWITCH?
  • terd1010 May 11, 2009
    I went this afternoon to develop pictures from my memory card and downloaded them to my PC tonight. Now when I try to take new pictures or delete those I've already printed and copied to my PC I get a message that the card is locked. The camera is a samsung L730
Anonymous
I had to replace two memory cards. Of course I tried the Lock slider thing on the side with no success. The card is cheaply made. I bought a different brand this time, Lexar. I think my old brand was Dane something. It seemed to happen whenever my battery got low. The card looked like a piece of cardboard and acts like one too!
Posted on Dec 19, 2007
Anonymous
Well I just had the same problem but every time i put it on unlock putting it back in my camera it slid to lock again. Well what I used was a very small piece of paper, wet it and put it in the crack to prevent it from sliding again. As for the card itself I will not be buying that brand again. I guess I'll try out others to see if I get the same problem.
Posted on May 31, 2008
Anonymous
Thank you! My card is unlocked!
Posted on Apr 09, 2008
Anonymous
On the card itself there is a little plastic slider where you can physically lock or unlock the card.
Take the card out of the camera and slide the little piece to the unlocked position.
Posted on Nov 06, 2007
Memory Card locked
this solution is from a another website about card error... i dunno if this will help fix ur problem but i hope this will give u idea how to fix it... okay.. tell me if this works, coz a lot of people were encountering the same prob as u.. thank God i havent encounter this error...good luck..
Troubleshoot:
Memory card is used by digital camera to store the photos it takes. Popular memory cards include SD card, CF card, xD-Picture card and Memory stick. For some reasons, memory card may get damaged on power shortage, or removal of memory card on picture shooting or viewing, or other various and unknown reasons. Usually, you will see error message like "memory card error", "card locked", "card error", or an error code on your camera screen and the valuable pictures on the memory card could disappear and be lost. Some cases, your camera or Windows may prompt you to re-format the memory card and refuse to take new pictures or view old pictures.
Solution:
Once you have your memory card damaged, it is highly recommended to stop further operations on the memory card (e.g. taking new pictures, or delete, format the memory card). Data recovery software like "CardRecovery" is able to recover the lost pictures in most cases.
First, you need to confirm your memory card can appear as a drive letter in "My Computer", which will allow recovery software to access and recover the lost photos. You may try to connect your digital camera to your computer, if a new drive letter appears in "My Computer", it is OK. Otherwise, you need to prepare a USB card reader. There are many card readers available in market (e.g. SanDisk and Kingston). You can buy one from Amazon or BestBuy.
Then, you may download and install CardRecovery to your computer. Launch it from Start Menu -> Programs -> CardRecovery. You select the drive letter of your memory card, and destination folder for save the recovered files. CardRecovery will scan your memory card and locate the recoverable pictures. The process is quick and easy. Usually it takes less than 15 minutes.
Can I re-use the corrupted memory card?
For data protection, CardRecovery performs read only operation on your memory card and it does not change the data on the memory card, so it does not repair or fix the memory card. If you need, AFTER you have recovered your lost photos from the card, you may try to format the memory card before re-use. It is suggested to perform enough read/write test before using it again to take new pictures. If you are worrying that the memory card is unstable and may cause further data loss, purchase and use a new memory card. Your valuable and irreplaceable photos are more important than memory card. Memory card is very cheap. A new 2GB SD, CF or xD card is less than $10.
credits: www.cardrecovery.com
Sep 13, 2009 | Canon PowerShot A75 Digital Camera
Memory card locked
this is from cardrecovery.com... whew a lot of people get this error... hope all of u resolves this..
but before u truobleshoot for recovery of pictures, check first the slide on your memory card (card protection) slide it both ways and check it... someone advices from a thread to use paper clips to pick the slot of the cam where u put the card, it work for him but i think its not a good idea coz it may damage the slot.. okay.. if there is still an error u can bring it to a tech person (canon support service) or just try to recover ur files...
Troubleshoot:
Solution:
Sep 12, 2009 | Canon PowerShot A470 Digital Camera
Locked memory card
Your camera is telling you the lock switch on the card is locked.
Take the card out of your camera and look on the side. There will be a little switch. One side of the switch says locked and the other side says unlocked. Move the switch from the locked position to the unlocked position and it will work for you.
Rob
Mar 09, 2009 | Canon PowerShot A620 Digital Camera
Pc won't read new images off camera
Have you checked to see if you are recording to a separate file?
Mar 12, 2008 | Olympus Stylus 710 Digital Camera
Memory Card Locked
:'( i'm in the same situation right now! :(((( I want my pictires back! i don't know what to do!
Jan 04, 2008 | Canon PowerShot SD1000 Digital Camera
Memory card locked!??
What you need to do is take out the card, and on the side of it there should be a little gray thing which can slide up and down. It needs to be slid all the way up. I hope this helps!!
Dec 26, 2007 | Pentax Optio W10 Digital Camera
Memory Card Locked
There is an option to lock the memory card, so here's what you do. Open battery slot<remove card<there is a lock tab just switch it to unlock. tab is on side of card on SD card
Dec 08, 2007 | Samsung Digimax D53 Digital Camera
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
Jul 05, 2007 | Pentax Optio E10 Digital Camera
Samsung Digimax S500 Digital Camera Logo
1,303 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
