It connects to router but will not pull up web pages I am running windows vista 32 bit
SOURCE: Acer Aspire 4315 can't connect to internet through wireless ADSL router
netsh int ip reset reset.log
netsh winsock reset catalog
Reboot
SOURCE: ACER 5720 WIRELESS CONNECTION PROBLEMS
can you pull up your router, I had this with an acer last week, I had set it up on my router then taken it to the clients house and it wouldn't work, the thing was that it never droped my router and was in the my network places several times. as soon as I realized that I deleted all of the routers and anything that wasn't supposed to be there and just went to make a new connection and bingo i worked. also don't forget the encryption key if you put one in you will need it to get on you network, good luck
SOURCE: Wireless connection slow
Same problem. RESOLVED it by going to device manager (hold the Windows Logo key near the space bar and hit PAUSE) Click hardware tab, and then device manager. click the plus next to network adapters to expand it, then right click the atheros wireless connection and go to properties. Click advanced, then find the power save mode. click it, then chose turn off on the right.
did this and my wireless is working normal again. hope this helps.
SOURCE: Problem's with built in wireless card
A friend of mine had a similar problem for whole 6 months until i uninstalled Norton. So if you use Norton Antivirus use this tool to remove it:
ftp://ftp.symantec.com/public/english_us_canada/removal_tools/Norton_Removal_Tool.exe
If link doesn't work use this link: http://majorgeeks.com/Norton_Removal_Tool_SymNRT_d4749.html
SOURCE: Cant access internet through wireless network.
if it flashes orange it is trying to connect and detect the internet, if you are connected to your wireless router but no internet check the security keys on the router and the laptop if they are the same, I guess you get the error limited connectivity, and if possible check for programs that could cause your wireless to not get the internet but get connected to the router, check for network magic uninstall the program from your system restart the computer try connecting again.
worst case that can happen is you can try uninstalling the wireless drivers and reinstalling it if the wireless devices gets an error during installation of the driver then you will need to replace your wireless card in your laptop, orange flashing in router meaning it does not detect internet from the modem ^_^
These are the general steps to all wireless connectivity.
Click the link below for proper cable connections in setting up your wireless network.
This link also provides somewhat a checklist on what you need for wireless connectivity.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
If you need more help come back.Post /
thumbs / testimonial are
welcome!
Step 2:
Select your Wireless Network Name or SSID then click Connect.
NOTE: If the wireless network name or your SSID is not listed,
the SSID Broadcast on the router might be disabled. For instructions
on how to connect to the wireless network with the SSID broadcast being
disabled, click here.
If the computer is not detecting any signal or is not seeing any
wireless network, change the channel of the router. For instructions,
click here.
If WEP/WPA is enabled on the router:
Step 3:
Enter your wireless network WEP/WPA Key on the field provided then click Connect.
NOTE: To learn more about WEP/WPA and other Wireless Settings, click here.
NOTE: Make sure Display characters is checked, to display the WEP/WPA key used by the router. You can get the passphrase or network key from the encryption that has been generated (if using WEP network security) from the router's web-based setup page. If you're using WPA network security, the network key is the key for passphrase.
Make sure you enter the wireless network's WEP or WPA key not the Passphrase.
It is also possible to make a wireless
connection even if the wireless security is disabled on your router. If
you don't see any network SSID from your network list, make sure your wireless adapter/device is ON and your router is in good condition. If your router shows any unstable occurrence, click here.
Related Article:
Configuring File and Printer Sharing
Unable to connect to a wireless network using WEP in Windows Vista
Windows Vista Articles Listing
Encountering Difficulty Connecting a Wireless Computer/s to the Internet when Connected to a Linksys Router
Setting-Up the Wireless Settings on a Router
Assigning a Static IP Address on a Wired Computer
