error -43 fnfErr: File not found
Could be many things, we should start with this...
"Try Disk Utility
1. Insert the Mac OS X Install disc, then restart the computer while holding the C key.
2. When your computer finishes starting up from the disc, choose Disk Utility from the Installer menu at top of the screen. (In Mac OS X 10.4 or later, you must select your language first.)
*Important: Do not click Continue in the first screen of the Installer. If you do, you must restart from the disc again to access Disk Utility.*
3. Click the First Aid tab.
4. Select your Mac OS X volume.
5. Click Repair Disk, (not Repair Permissions). Disk Utility checks and repairs the disk."
http://docs.info.apple.com/article.html?artnum=106214
Then Repair Disk on the external drive.
Then try a Safe Boot, (holding Shift key down at bootup), run Disk Utility in Applications>Utilities, then highlight your drive, click on Repair Permissions, reboot when it completes.
(Safe boot may stay on the gray radian for a long time, let it go, it's trying to repair the Hard Drive.)
If perchance you can't find your install Disc, at least try it from the Safe Boot part onward.
If TM display doesn't even show up, see this...
http://pondini.org/TM/E4.html
And also i share a link to another error issues.
http://www.macworld.co.uk/feature/mac-software/common-mac-error-messages-3502033/
Thanks,
Mac Support
