Question about HP Computers & Internet
If the door of your HP Officejet J5783 printer is not closing properly, there may be a few possible causes for the issue. Here are some steps you can try to fix the problem:
If none of these steps help, you may need to contact HP or a technical support team for further assistance. It is also a good idea to check the documentation or manual that came with the printer for any troubleshooting tips or recommendations.
Posted on Dec 21, 2022
SOURCE: Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Posted on Feb 28, 2009
SOURCE: After clearing paper jam, display light states back door not closed. It is closed, but I can't print
hai. you try re-start the machine, if your problem not solved, Please check the back door sensor or limitswitch.
Posted on May 25, 2009
SOURCE: i "m getting error 252*
Welcome to FixYa!
Try to reset the printer by doing the following;
1. Turn ON the printer.
2. Disconnect the USB printer cable at the back of your printer while the printer is ON.
The USB printer cable looks like the image below.
3. Open the Cartridge Door and remove the cartridge. Refer to the image below.
4. Wait for the "Insert Cartridges" message to display on the message screen of the printer.
5. Disconnect the power cord from the back of the printer.
6. Wait for 1 minute.
7. Reconnect the power cord.
8. If the printer does not turn on, use the power button to turn it on.
9. Reinsert the cartridges.
10. If the printer prompts you to print a calibration page or requests for a cartridge alignment, please do so.
11. Reconnect back the USB printer cable and try to print.
I hope that this would be helpful to you, thank you for usng FixYa!
Jas247
Posted on Mar 06, 2011
SOURCE: I cannot scan using hp
Thank Dear, I got your answer.
First, if in your computer install previous scanner driver then first uninstall it after doing that please restart your computer.
2nd, connected your device with computer and insert its driver software in CD ROM. After sometimes you will watch the new window where shows device has found and install your driver. When you watch it then click next and install your driver.
3rd, Restart your computer
It become okay in stead of other major fault in your device.
Thanks
Posted on Apr 18, 2011
