SOURCE: dryer wont start anymore
If the drum won't rotate, you may have a broken belt. I had a Kenmore and as I recall, you have to pull up the top section to see inside. Good luck.
SOURCE: Kenmore gas Dryer Heats at start then stops heating
Usually problem like this with electrical solenoids located on the top of gas valve inside the dryer. They need to be replace.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
SOURCE: how to remove front panel from kenmore 90 series gas dryer
Gently pry top of dryer in front corner area. Disconnect door switch inside front. Remove 2 sheet metal screws from inside front. Let me know, Thanks, Sea Breeze
SOURCE: my kenmore 80 series electric front loader dryer
POSSIBLE THERMAL FUSE/S. MAY BE ONE ON HEAT ELEMENT CANISTER AND ONE ON BLOWER HOUSING
