Question about Ariston Technologies LL65 Built-in Dishwasher
Why Ariston lbf51 washing and drying light rapid flash
Dado
    Master:
  • Ariston Tech... Master
  • 509 Answers
AL03 - Drain Timeout (drain problems)
LED 1 (washing) and LED 2 (drying) flashing.
Probably the siphon of the apartment is clogged.
  • Remove the drain hose and make sure that is not clogged.
  • Drain water in a bucket.
  • If the dishwasher drains the water, clean the siphon of the apartment.
Why Ariston lbf51 washing and drying light rapid f - 24501411-0h3kxpflbez5mdeb5anq3st4-5-0.jpg
Dado
Posted on Nov 02, 2015
  • Tim Geraghty-Groves
    Tim Geraghty-Groves May 28, 2018
    Dado, what does the 1st and 3rd indicator light code mean?
2 Related Answers
Anonymous
SOURCE: eco and rapid cycle light flashing rapidly
had something jamming pump impeller which prevented machine pumping water out. The motor is connected by a bayonet fitting to the pumpand is easy to get at and clear obstruction.
Posted on Dec 20, 2009
Testimonial: "problem fixed"
Anonymous
SOURCE: I have an Ariston LL65 and the eco and rapid light are flashing
I have the same issue, so Dish-washer Ariston LL65 with Eco and Rapid light flashing. Can you help me to undestand the issue and solve it ? thank you, Regards.
Posted on Dec 25, 2010
Why is the Rinse Cycle and Drying not working
Unfortunately you did not specify the model dishwasher so I'll give you a general answer.
(The indicator light, straight from Washing moves to completion stage where the light blinks rapidly) I believe you means the "End LED" (LED 3) blinks rapidly. If this is true and according to your description of failure (no drying, no rinsing) I think that appeared alarm AL04. It means the thermistor (NTC) not compliant - probable failure of the component that detects the temperature .
I suggest you to check: thermistor NTC, wiring and electronic.
24464652-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Rapidly flashing any combination of four LED diode means failure.
Dado
May 20, 2014 | Ariston Technologies Dishwashers
Ariston l63 is not rinsing proper cycle but instead flashing 12hr light
Error messages,
Your dishwasher is equipped with a safety system which is able to detect any operating anomalies. These anomalies are reported by one or two wash cycle indicator lights "G" flashing rapidly.
24463930-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Flashing LED diode above the mark 12h (drying) indicates faulty NTC thermistor. So, could be faulty: thermistor NTC, wiring between NTC and control board, control board.
Dado
May 20, 2014 | Ariston Technologies L63 Free-Standing...
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
Dado
May 15, 2014 | Ariston Technologies LL65 Built-in...
L 63 B NA Ariston
24238319-0h3kxpflbez5mdeb5anq3st4-3-0.jpg In this case could be:
  • Drain motor disabled
  • Filters clogged
  • Drain hose blocked
Dado
Apr 24, 2014 | Ariston Technologies Dishwashers
Ariston L64 dishwasher first 2 lights flashing what does this mean please!
Ariston LI6401-Washed a load. Last light on R control panel (Eco Wash) is blinking rapidly and didn't dry the dished.Turned pwer off then on. Did same type of wash. New maching-This is about the 6th wash
Mar 16, 2011 | Ariston Technologies LI640S Dishwasher
Sep 01, 2009 | Ariston Technologies LL65 Built-in...
Dishwasher, Ariston LI62, kept flashing on R
hi there.....this usually happens when the base of the machine is full of water.....switch the machine off ....remove the two plactic inspection panels at the bottom of the machine and dry out the base....check that all fittings and fixtures in the main cabinet are secure and not leaking..particularly the transfer tube from the wash pump to the upper spray arm..(machine needs to be pulled out of its position to check this as it is at the rear)
regards Sir Galahad
Aug 18, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston a1400wd washer dryer will not start and delayed timer, rapid and on off lights continiously flash. checked pump and nothing appears to be affecting it.
Bolody thing will not tumble dry, it goes through the motions but the washing still comes out wet after 3 hrs, have tried continuosly but same result - certainly wont be buying another one of these pieces of junk
Sep 07, 2008 | Washing Machines
Ariston a1636 washing machine
I have the same problem, did this get solved for you?
Jan 08, 2008 | Ariston Technologies AW149NA Washer
Ariston Technologies LL65 Built-in Dishwasher Logo
383 people viewed this question
Top Ariston Technologies Dishwashers Experts
Renee Knafel-Bullock
Tom Chichester
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
