A
Anonymous Posted on May 25, 2014
How do you put a line under the word or letter
How do I underline letters and numbers
Dick O Reilly
Level 3:
  • Master 3,594 Answers
  • Posted on May 27, 2014
Dick  O Reilly
Master
Level 3:
Answers
3594
Questions
Helped
609252
Points
6852
You didn't givr\e a make or model but backspace to desired point, press shift and the key to the R. of the zero key.
DickyO
5 Related Answers
Anonymous
  • Posted on Sep 17, 2008
SOURCE: printing wrong letters and numbers
Typing wrong letters.
Please help immediately
Anonymous
  • Posted on Nov 24, 2008
SOURCE: typing wrong letters and numbers
Escribe las letras y numeros diferentes
Dick O Reilly
  • 3594 Answers
  • Posted on Jan 05, 2010
SOURCE: the letters scramble after a few lines. I mean if
It sounds like something is interfering with the printwheel. Remove the P/W, rotate it and look for bent or broken spokes, Be sure the correction tape is a non tacky type sticky ones will give you fits.
DickyO
Anonymous
  • 32 Answers
  • Posted on Feb 19, 2010
SOURCE: when typing wrong letters and numbers type
You might have a "proportional space" printwheel but the pitch selector is on 10, 12, or 15 instead of PS. OR it is on PS but you have a normal print wheel. Try selecting different pitches. Another thing that causes that problem is sometimes the ribbon or correction tape gets caught in the printwheel.
Anonymous
  • 405 Answers
  • Posted on May 30, 2010
SOURCE: when typing, incorrect letters appear. For
You will need to replace the daisy wheel.
How to underline a letter?
Word Document Step 1 Launch Microsoft Word.
Step 2 Open the document that contains the text you want to underline.
Step 3 Highlight to select the letter in the Word document.
Step 4 Click the "Home" tab in the main menu ribbon.
Step 5 Click the "Underline" button in the Font tools group or press "Ctrl-U" on your computer keyboard to underline the letter. To use decorative underlining, such as dashes, dots or a wavy line, click the down-arrow button next to "Underline" in the Font tools group and select your preferred line style from the Underline Styles pull-down menu.
Step 6 Save the document to store your changes.
Underline a Letter in a Gmail Email Message Step 1 Sign in to your Gmail account.
Step 2 Click the "Compose" button to create a new email. Fill in the email recipient's address, add a subject line to the email and enter the message text in the usual way.
Step 3 Highlight to select the letter in the email body text that you want to underline.
Step 4 Click the "Underline" button in the toolbar above the email message field or press "Ctrl-U" on your keyboard to underline the letter.
Step 5 Send the email with the underlined letter in the text.
Underline a Letter in Microsoft PowerPoint Presentation Step 1 Launch Microsoft PowerPoint.
Step 2 Open the presentation that contains the text you wish to underline.
Step 3 Highlight and select the letter in the PowerPoint slide.
Step 4 Click the "Home" tab in the menu ribbon.
Step 5 Click the "Underline" button in the Font tools group or press "Ctrl-U" on your keyboard to underline the letter.
Step 6 Save the presentation to store your changes.
How do I change the size/font of the letters? Bold and underline too?
To change font and pitch, you need to buy a different printwheel. machines came with a prestige elite 12 printwheel. Prestige elite has small letters and 12 puts 12 charactors per inch. Letter gothic is larger size letters. Google search for ibm wheelwriter printwheel, also called a daisy wheel.
1helpful
2answers
How to set the name plate on the brookstone electronic name plate
1) use a pin to press and hold "reset" to clear the display
2) press and hold "S" to get a blinking underline
for each letter, press the "C" triangle until you see the letter you want, then press the "E" square to enter that letter and advance to the next letter. when done, just wait for it to timeout.
I'm unsure how to display things more than 16 letters.
2helpful
When texting and putting in "is" i keep getting HQ. Can i reset this or remove it from the phones memory for predictive words?
take off predictive text... either keep the star key or the hash key tioll you see the symbol in the top corner with the letters underlined, when the line underneath them goes then predictive text is off
Mar 26, 2011 • Cell Phones
2helpful
2answers
How do I amend the underlining of my text when writing a message?
Welcome to Fixya. The underlining of text when writing happens when the Predictive Text option is Enabled. When in text mode you can use the Hash Key (#) under number 9 Key to change the case of letters or prediction.
Thanks for using Fixya.
2helpful
Keeps underlining in red when using ms word
One thing you probably will have noticed is the spelling mistakes in the letter. You should have typed the letter exactly as it was, and left any spelling errors in. More than likely, the spelling mistakes are underlined in red in your document. Anything with a wiggly green line under it is a grammatical error, (or what Microsoft Word insists is a grammatical error). You can turn these off and on if you like. To Turn the wiggly red and green lines on and off, do the following.
Check the link to solve your problem :--
http://www.homeandlearn.co.uk/mw/s1p9.html
Waiting for your feedback......................Do reply !!!!!!!!!!
3helpful
2answers
My keyboard wont type anything, the mouse works, but when i try to type it wont do anything, the buttons do work because when i open word to try to type if i click f the file drops down and when i click v...
Somehow the left ALT key is stuck in a pressed position. Usually when you press left ALT and the letter underlined in a menu, it deploys that menu. In the File menu, the F is underlined and in the View menu it is the V that is underlined, hence the behavior.
Hope it helps.
I used a shredder on my hardrive and I put in the windows 98 number in the registration page and it keeps coming back as an invalid registration number
Are you sure this is a valid number? I mean check the numbers especially for zero and the letter O. They will usually try to put a line through the zero to distinguish it from the letter. Let me know if this works.
k24674
ADMIN Andrew
ADMIN Andrew
