Jandy Aqualink Rs4 One Touch Control System Control System Logo
A
Anonymous Posted on May 24, 2014
How do you reset garbage disposal? - Jandy Aqualink Rs4 One Touch Control System Control System
2answers
Is there a reset button on the badger disposal?
If your garbage disposal won't run you may need to reset the garbage disposal using the RED overload protector button on the bottom. ... Turn on a cold stream of water and turn the disposal switch to "ON" position, the disposal should now run again. How to Reset Garbage Disposal InSinkErator
Use the wrench provided and turn disposer counterclockwise wise (of course the power is off.. do not repair it is better to replace with a new unit. Use 1/2 Hp minimum. Available at HD or Lowe's
Where is reset button on gemline garbage disposal
To reset garbage disposal follow these simple instructions:
  • Make sure that the disposal switch is in the "OFF" position.
  • Gently press the red button in to reset garbage disposal. ...
  • Turn on a cold stream of water and turn the disposal switch to "ON" position, the disposal should now run again
1helpful
Is there a reset button on badger 15ss?
Usually the reset button is located on bottom of disposal near where wire is connected..
Use your hair mirror to look at bottom of disposal.
More disposal resources for troubleshoot, maintenance, repair and installation:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Reset badger1 insinkerator
Copy following link:
Reset button is located on bottom of disposal
Gene
h
Titan garbage disposal
Push reset button located bottom of disposal? Use broom stick and rotate stuck cutter disk?
Copy following link to troubleshoot by type of problem:
Titan appears to be repackaged sinkmaster garbage disposal.
There is no service manual or installation manual on brief web search. However link above has manuals sinkmaster and other brands .
Add a comment and say what you discover
MY BADGER INSINKERATOR XP IS NOT SPINNING AND THE RESET BUTTON IS NOT RESETTING. WHAT WRONG.
It sounds like the garbage disposal has a fatal short, and the reset won't push in because there is an electrical failure inside the unit.
I get power through the reset button. No humming, no nothing. Is it a bad motor?
If i understand correctly, you tested the wires where they connect to the garbage disposal.
Those wires connect before the garbage disposal reset button.
If the reset button is locked in, then the reset is not popped out.
If reset will not reset, then the popped-out reset will push in but not click down.
If the reset is clicked in, and you hve 120V on the line, and the garbage disposal doesn't make any noise, then the motor is bad.
There are no replacement parts for garbage disposal.
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
ZJ Limited
ZJ Limited
john h
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
