Question about RCA P52926 52" Rear Projection Television
Screen cover rain bow affect
How does acid rain affects plant growth. Mention any five
It can decrease the growth of many plants.Look up https://prezi.com there is a great presentation on the affects of acid rain on plants.
Sep 13, 2017 | Garden
How to get ridmof Black soot like covering citrus trees
Is this actually soot, or like a fungus . Fruit leaves and or branches trunk.
Did this blow in on the wind rain.
Won't hose off?
Locate , contact county arborist take samples fruit and or leaves.
They diagnosed and iron deficiency looking at some oak leave..
Post a picture hear if you can maybe someone can I'd .
Are other type trees affected?
Jan 03, 2017 | Cars & Trucks
I Can not see the screen on my pitney bowes dm100i?
Screen contrast probably needs to be reset which can be done by:
1. Unplug the power cord
2. Press the #4 AND KEEP HOLDING IT DOWN UNTIL METER IS FULLY started aafternext step.
3. Keep the 4 button pressed & plug the power cord in, while keeping the 4 button held down.
After meter fully boots the screen will be restored to normal if contrast settings were the problem.
If this doesn't resolve the problem, the screen or control panel is bad & should be replaced. This should be covered under yourpPitney Bowes warranty while meter is onlease.
Apr 29, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
What affect the arrow velocity?
The speed of an arrow depends on the draw weight of the bow, you own draw length, the limb material and the energy profile of the bow. The wind condition, the humidity and the rain slows down the arrow and the faster an arrow travels, the flatter the flight trajectory and less deviation from wind.
Aug 26, 2012 | Betsey Johnson Archery
Projection tv has 3 versions of what is on tv instead of one
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 26, 2010 | RCA D52W23 52" HDTV CRT TV
Battery in my 2006 Audi A4 2.0T Quattro is exposed to rain.....
I checked prices at a large parts store chain, and they had 3 battery choices for your car, 2 were $150, and a 3rd was $90. Was the $150 u mentioned for installation only? I'm wondering what they charged for the battery? I' m not familiar w/ the location of the battery in your car (some GM models are located under the rear seat!). Any rain entering the engine compartment (there shouldn't be much due to gaskets/weather stripping around the hood), would not harm the battery. Actually, heat is an enemy of the battery, and it's plenty hot under the hood, so in theory, any rain that did enter and contact the battery would be good, as it would have a cooling affect. Eliminating the cover may have been done as a way to dissipate heat. Let me know where the battery is located, as it may be someplace unique, but if it's under hood like most cars, rain is not an issue. I do want to know what the total cost of the battery was, and if I understand correctly that $150 was for installation, not the cost of the battery.
Dec 15, 2008 | 2006 Audi A4
2004 Pontiac Grand Am in rainy conditions
hi cannot see the rain affecting the gearbox but rain can affect the sensors that tell your box what to do just for saftey reasons make sure alls well on your front wheels [no loose joints play in bearings tires ok if its ok] check all your wiring connecters to your sensors by dissconnecting them check them for signs of water contamination then clean them and grease the joints try again yates210456
Sep 21, 2008 | 2004 Pontiac Grand Am
Is my bulb going bad!!!!
Without seeing your Tv it is hard to say what is really going on.
The cloudy picture sounds like one of your "bulbs" needs to have it's fluid changed, not "bulb" replacement.
Rain bowing normally means convergence adjustment or circuit repair is needed.
May 25, 2008 | RCA P52926 52" Rear Projection Television
3d picture
multicolored 3d effect is a problem with what is known as convegence... ussally there are two large chips (ic) that blow. gennerally they have to be replaced mabe some fuses and resistors..
May 02, 2008 | Samsung HCL4715W 47" Rear Projection...
Trane HVAC Unit
If your condenser blow air up through the top of the condenser and you are concern about rain water affecting the unit.
You can install a roof or rain hood about 4ft above the unit to keep the rain off, The unit must be able to blow air off without causing Hi head pressure to affect the unit, The condenser must breathe or desipate heat freely.
Tell me if your question answered or if it works for you.
Mar 31, 2008 | Heating & Cooling
RCA P52926 52" Rear Projection Television Logo
48 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
