SOURCE: Copystar CS1810 shows error code J00. How do I fix
J00 means that the machine did not pick. remove the cassette and the put back and press start again
SOURCE: I HAVE A COPYSTAR CS1810
This code indicates a fault with the Fuser Unit/Thermistor or PS-PCB and should not be reset until the fault is corrected.
You could try resetting the fault as follows but this may damage the machine further.
Turn the copier off, while holding down the Size Select Key turn the copier on and keep it pressed until the copier shuts down.
