The paper is being pulled to one side in feed tray causing paper to crunch up. suspect something caught in roller. need to remove outer cover to check internal feed rollers
SOURCE: paper won't feed, HP printer dock series 3
I had this problem (among many others with my printer). I found that just cleaning the front roller with a damp paper towel fixed it. Wipe it carefully and let it dry before reloading the paper. The rubber on the roller seems to lose it's ability to pick up the paper if it sits unused for any length of time, so wiping it with warm water and drying it works. Good luck. Lynette
SOURCE: I have an Easy Share printer dock series 3 that has paper loaded
Dirty rollers? I had the same problem and think the rollers are no longer sticky enough to pick up the paper due to a coating of dust... maybe cleaning the rollers would work?
SOURCE: screen says paper jam, can't find anything
close properly your paper jam cover at the back of your printer down side. if not clean and check the sensor for paper jam.
SOURCE: Paper will not feed into the EasyShare printer Dock series 3.
The paper sensor in the printer might be disturbed please check that one.
SOURCE: Won't collect paper
Cleaning the rollers with an alcohol is not advisable
you need to call tech support regarding this problem
the number is 1800 421 6699
