Toshiba Satellite A135 Notebook Logo
A
Anonymous Posted on May 24, 2014
Fn is not work, so how to mimimize brightness of M115-s3154 toshiba laptop?
NOEL
Level 3:
Top Expert:
  • Toshiba Master 8,606 Answers
  • Posted on Apr 12, 2015
NOEL
Toshiba Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322077
Points
68630
Have you tryed going into your display settings?
3 Related Answers
Anonymous
  • 1189 Answers
  • Posted on May 08, 2010
SOURCE: i have a toshiba satellite m115 s3154. i cant find
  • Hi, first, go to the “Control Panel” select and open. “Next, click to open the “Device Manager, or Hardware & Sound.” Select, “view, or update" Drivers; click on to open the Disk Drive icon. In the Device Status, check to see if, “working properly” If so do the following; Click on the Driver button,” once the window open “check (two) areas. Rollback Driver, “if this area is not “Grayed-out; rollback drivers, “Apply, and click “OK.” Restart the computer.” The second area is the “Update Driver,” Click to update! Apply and click OK. Final step is to “restart the "computer” Important sometimes the ‘Drivers” can be “inactive mode” not disabled, nor recognized), just not functioning correctly. In a final attempt to get, the drivers up and running, take these steps: Click on the “Update Drivers” choose (“Browse my computer for driver software”), select to open. Next, select: (“Let me pick from a list…”) ‘once the next ‘window appear, click to highlight” the Driver, and click the Next (tab), follow all instructions thereafter; restart the computer. “Helpful Ratings Feedback is appreciated, thanks .”
Anonymous
  • 15 Answers
  • Posted on May 10, 2010
SOURCE: toshiba m115-s3154 laptop won't power on
if its not the battery or the power adapter then it could be something to do with bios settings or corrupt master bot records
Anonymous
  • 15 Answers
SOURCE: SCREEN PROBLEMS Toshiba Satellite M115 S3154.
maybe it has to do with your power settings or screen view properties which can generally be accessed by rgiht clicking on the desktop then properties or else nvidia if u have that.
How to adjust the brightness on theMonitor
Press FN key (second key at bottom from left corner of KBoard) and hold it down and press F3 (fourth key button from top left of keyboard) to increase brightness and F2 to decress brightness. Should see a picture of a sun with an up or down arrow on the function key.
My product key doesn't work when I tried to install new operating system
What msg. does it give you? Check Prod. Key and type exactly as given,. Is the OS a genuine copy you purchased or a friend gave you?
I have a Toshiba satellite l305d-s5974 and i want to completely reset it to factory settings
Insert the factory CD that came with your machine and restart and follow the on screen instructions. Format the drive and re install operating system you should have the disks to do this if not go and purchase an operating system software program and go from there. John
2answers
1helpful
Turning on wireless
Slide switch on front edge, make sure it's switched on.
1helpful
I have a toshiba satellite m115 s3154. i cant find the sound driver for the laptop.
2answers
Toshiba m115-s3154 laptop won't power on
isolate the problem very well. by replacing the battery, and the power adapter. if one of them didn't work, it is defective. replace it.
SCREEN PROBLEMS Toshiba Satellite M115 S3154. Distortion when opening/closing screen. Sometimes it will go blank with flashlight readable screen. Any history of wiring problems or plug problems relating to...
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
