Question about Kenwood KM200 Chef Food Processor
How do you remove the top and motor from KM200
George Bishop
    New Friend:
I have the same problem, removed screws but it won't pass over the front gearbox spigot.
Posted on Mar 29, 2015
  • Chris W
    Chris W Dec 01, 2016
    Did you ever get an answer on how to remove the top?
  • Anonymous Apr 29, 2017
    Slip a screw driver up the front by the slow speed outlet and gently prise it outwards and upwards Will pop off without breaking, even on an older machine
How do I fix my Kitchenaid food processor? Motor hums but center shaft is stuck and won't turn.
Hi Eric, you are going to have to get the motor out and yes it will be because of the spilled liquid fusing/rusting the motor armature shaft into the bronze bush. Those motors are very expensive so worth a go to save it. You will have to get the plastic sleeve off that shaft first before you can get the motor out. Removal will destroy the sleeve. I drill a hole through the top of the sleeve, side to side leaving about 5mm of meat at the top. I shackle a chain through it and attach it to my bench leg and then accelerate the whole motor unit away in a straight line. The shaft needs to be pointing at the attachment point on the bench or it can slip from your hands creating more grief. It will only take 1 to 3 pulls, 1st one doesn't work do it harder, same with second pull and harder for the 3rd. The chain needs to have welded links or the chain will break. That is far the easiest removal method I have found, other methods could involve hacksawing it down one side being careful not to damage the metal shaft or melting a line down 1 side to split it open with a soldering iron. Once that is off then remove base, detach motor wires from pcb and remove the screws under the plastic caps on top of the top housing. Then it will be working away with levers and a spanner on the shaft and CRC, sweat and time. If you strike trouble after that email me
[email protected] Cheers Ross
Apr 03, 2015 | KitchenAid KFP600 Ultra Power 11 Cups Food...
Sunbeam multiprocessor model lc6200 runs full speed all the time
As other contributes have said, remove all the screws from the base, the spindle can be released by caerfuly prising out the small plastic clip halfway up the spindle, it will slide easily off and the large spindle drive wheel can be removed. Push the control knob out from behind, the knob and e surround come out as one unit. Remove the accessories holder and remove the two screws holding the top cover on. Now turn the unit the right wat up to start to release the top. Carefully prise the top cover off, there are two plastic clips at the front. Now you have exposed the top of the unit and the safety switch actuator. Remove the screws, the hardest job is to release the actuator rocker arm. I could not release the pivot support, so took the rocker off the pivot. Now you should be able to lift the cover off the motor and Access the control board. There are two screw holding the control assembly in place and two which hold the circuit board to the switch. Replace the Triac and diac then reassemble.
May 21, 2012 | Food Processors
Spindle shaft on KFP600AC has stripped . Have replacement but cannot remove old one. we are seniors and not too st.rong physically .! Any suggestions. Thank you in anticipation. Lysbeth
The shaft is spinning inside the sleeve. So is should not be hard to remove. With a DLC-7SP, I grabbed the spindle with some pliers, channel locks might do well and put a handle of a screwdriver between the pliers and the top deck and pried. Second attempt and it pulled up easily. Place the screwdriver beside one of the top deck screw covers to transfer force directly to the motor. Otherwise top deck would probably break.
Jan 29, 2011 | KitchenAid KFP740 CR Food Processor
How do you get the motor shaft cover off? I need to replace the old one.
Oct 07, 2010 | Cuisinart DLC-7SFP Pro Food Processor
Cracked plastic sheath on the motor drive shaft
Clean the old shaft to remove any contamination.
New one can be driven on with a hammer and block of wood.
Jul 08, 2010 | Cuisinart DLC-7SFP Pro Food Processor
Sunbeam LC6200 won't turn off. Only runs at full speed unless the bowl lid is disengaged (the safety swtich still works). Have opened it up and the Pulse microswitch seems ok, as does the rotary speed/off...
OK this is the fix for the LC6200 that worked for me. Unscrew top cover (2 screws) then another screw holding internals to external case. Carefully remove safety switch lever (use long nose pliers from the top next to lever to squeeze plastic barb that holds the levers in to the plastic body). Remove all screws on the bottom. Open and undo the drive shaft pully nut clockwise. Pull out shaft and remove belt. Unscrew motor from chassis plate. From the bottom push out the plastic speed control dial with screwdriver. Remove motor and component boards. Check microswitches. Then remove diac DB3 and replace. Remove triac BT137 600v and replace. PS I used a 800v motorola MAC228 instead. Assemble in reverse. Good Luck.
denisprod
Feb 20, 2010 | Sunbeam Food Processors
How do i seperate the housing on a robot coupe processor
There are 4 rubber shoes on the bottom of the white or gray base. Twist & pull these out. With a TORX long shank screwdriver (nothing else works, trust me) there is a screw way down in each hole. After removing the screws a gentle but firm bump should loosen the base. If you ever need to replace the motor, on the top around the drive shaft you will see three round plugs/disks, remove them by prying up with a pocket knife (works best) this will give you access to the three motor bolts.
Feb 20, 2009 | Food Processors
Part removal and replacement
The black plastic clutch has a left-handed brass threaded insert. Temporarily remove the motor to hold the shaft and remove the brass insert by rotating clockwise.
Dec 26, 2007 | Cuisinart BFP-703 SmartPower Duet Food...
Kenwood KM200 Chef Food Processor Logo
Top Kenwood Food Processors Experts
Ross Keen
ADMIN Canada
ADMIN Canada
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
