How do you retract a kwikset lever signature series exterior door tounge manually, lever moves up/down but tounge doesnt move out off latch
Kwikset Polished Brass Lido keyed entry Lever smart key 740LL 3 SMT CP K4
lever moves up and down (it isn't locked)
removed door knobs (levers in this case),
how can I move tounge out of door jam manually?
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
Since the exterior side of the lock only has a keypad and no lever, I'm
not sure what you mean by the "outside lever". Here is a clear, easy to
follow video of the installation. Please carefully review each aspect of
your installation against it to see if you can spot an installation
mistake: http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Since the exterior side of the lock only has a keypad and no lever, I'm not sure what you mean by the "outside lever". Here is a clear, easy to follow video of the installation. Please carefully review each aspect of your installation against it to see if you can spot an installation mistake: http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Another cause for the red LED blinking on your Kwikset lock, especially when it beeps 3 times is it could be jammed or misaligned. When this happens, check and see if the door is securely latched or aligned properly. If needed, you can also adjust the strike plate to get the latch moving freely again.
You can read more here: https://revolar.com/why-is-my-kwikset-lock-blinking-red/
Kwikset has a lifetime mechanical and finish warranty. Contact them from here:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
