Question about ULINE U-Line 2175BEVCS-00 2000 Series 24" Right Hand Glass Door Refrigerator in Stainless Steel 2175BEVCS-00
Replace circuit board Beverage Center - 2175BEVC
Posted by Chris on
Ge monogram beverage center has ice build up and not cooling
Anytime there is ice buildup it will not cool. Was the door left open? If so that would cause ice buildup. If it wasn't left open and it is a frost free model you have a problem with the defrost circuit. Unplug it and Manually defrost it with items removed by using a hairdryer and towels to absorb water from defrosting Afterwards it will cool again .If the defrost circuit needs service the unit will continue to frost up. Usually in frost free models there is a heater that goes bad.
Aug 01, 2014 | GE ZDBC240NBS Beverage Cooler
I do not have 12vdc at the circuit board where the fan plugs into. Any thoughts?
Has the 12v supply fuse blown? Check that and replace with identical value if it has
Jul 07, 2014 | Maytag MBV1976AAP Beverage Cooler
Saeco 7P Not Dispensing Product
Rick:
Here are some possible causes:
- for the top five selections (the ones that use espresso), the first sound you hear after making a selection should be the grinder starting. If no sound, check that grinder is receiving 120V.
- do the bottom 2 selections work (the ones that don't require espresso)? If not, inspect the ribbon cables leading from the selector circuit board in the door. The is a sharp edge on the door hinge which could damage these cables.
- if the selector circuit board was ever removed, it may not have been replaced so that pushing the buttons on the door actually depresses the microswitches on the board. To test, verify that you can feel a click when you push each button.
- it might be a circuit board issue. Having two machines allows swapping of circuit boards between machines. Hopefully, you can come up with at least one set of functional boards.
- Good Luck!
Dec 05, 2011 | Coffee Makers & Espresso Machines
I purchased a 52 bottle kitchen aid wine cooler. No matter where I set the thermostat, it is always 45 degrees and readouts are sideways "T's" instead of numbers.
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. arrow_results_summary.gif Get Adobe Acrobat Reader Click Here=> KUWA244PBS Parts List
and here=> KUWA244PBS User and Care Guide
If you should need the service manual you will need to cant me here=> HERE Reason is Whirlpool does not allow me to publish the SM here.
The beverage center and wine cellars have a temperature display for each zone. 12 volts
AC is supplied to the display board from a transformer in the unit compartment. The displays are only temperature displays and have nothing to do with any cooling function. A thermistor is used to sense temperature for each zone. The thermistor for the bottom zone is located inside the lower portion of the separator. The thermistor for the top zone on the wine cellar, (mid zone on beverage
center), is located in the upper portion of the separator. The thermistor for the beverage center upper zone is located on the inside of the 2-piece evaporator cover. It is on the right-hand side.
The mid temperature for the bottom zones on either unit are 60? Fahrenheit plus or minus 5 degrees. The mid temperature for the mid zone on the beverage center and the top zone
on the wine cellar is 45? Fahrenheit plus or minus 5 degrees. The mid temperature for the
top zone on the beverage center is 38? Fahrenheit plus or minus 5 degrees. I think at tis time you should check each section with a pocket size digital thermometer to cofirm tha the mechanical thermostat is within calibration. Click Here=> 4344690 Temperature Control
Click here for a=> KUWA244PBS Beverage Center Wiring Diagram
I believe the problem may be in the PCB transformer shown at the bottom right corner of the wiring diagram. It is possible o change the transformer but I have not been able to find the board that powers the LED temperature readouts. If needed let me know and I will call Whirlpool mfor you, Thanks, Sea Breeze
Oct 09, 2011 | KitchenAid KUWA244PBS Wine Cooler
Frigidaire ffbc46fsls beverage center refrigerator does not resume "on" condition after power glitch. If the unit is unplugged while running, then plugged back in, it resumes normal function,...
Wow if you have lost that much because the memory dumps during a power failure then we are going to need do something serious about that! May take me a while to come up with a solution but being the case I think you have a serious point to make. Acording to The
Frigidaire FFBC46F5LS Beverage Center User Manual
and on page 7 of the PDF
The default temperature for the beverage cooler is 41°F (5°C). The temperature after power failure will be the temperature set before the power failure. So something is wrong with the control board part=> Pc board,input ,display I believe I would call USA 1-800-944-9044 and ask why that may be happening. Below is a parts list.
Frigidaire FFBC46F5LS Beverage Center Parts
Hope this helps, Thanks, Sea Breeze
Sep 03, 2011 | Frigidaire FFBC46F5LS
Need to remove center console to replace seat belt. After removing 12 screws, console is still firmly in place. What else has to be done?
  1. Remove the two oval covers from the sides of the floor console. Remove the four (two on each side) retaining bolts. Lift or remove the front seat center armrest from the floor console.
  2. Remove one screw from the top rear end of the floor console (directly under the front seat center armrest.
  3. Remove four screws retaining the utility tray beverage holder to floor console. Lift or remove the utility tray beverage holder from the console.
  4. Remove two screws (directly under the utility tray beverage holder) retaining the front end of the floor console to the console panel front mounting bracket.
  5. Lift the floor console from the front and rear console panel mounting brackets.
Feb 27, 2011 | 1996 Ford Explorer
Skybox beverage dispenser. will dispense one can
I had the same problem. Found the cover where the beverages dispense to be rusted and not resetting. After the can dispenses, just push the cover back into position and this should help.
Jun 09, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
ULINE U-Line 2175BEVCS-00 2000 Series 24" Right Hand Glass Door Refrigerator in Stainless Steel 2175BEVCS-00 Logo
Top ULINE Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
Are you an ULINE Refrigerator Expert? Answer questions, earn points and help others
