Question about Kitchen Appliances - Others
Ehy does my whirlpool compact el05p refrigerator freezes up constantly?
Posted by Rich Fischer on
patrick dierckx
    Sergeant:
  • 310 Answers
Its possible the rubber on the door is worn out.
or the thermostat is bad
Posted on May 24, 2014
Fridge Freezes Everything
there is a motor with a flapper that opens and closes to keep your temp correct in the refrigerator side most likely the motor is bad and stuck open so your air from the freezer has constant flow to the refr side. the flapper is in the back of the refr behind a cover where the air flows in.
Apr 16, 2014 | Emerson Cr180 1. Cu. Ft Compact...
My compact refrigerator is too cold even turned way down almost off. Freezes soda cans and makes them blow up.
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 02, 2011 | Haier HNSB03 Compact Refrigerator
My refrigerator leaks water on one side & the water collects in one of the vegetable coolers. I am now unable to use that vegetable cooler & am having to constantly wipe up. The seals appear to be...
I have Model ET8CHMXKQO-3 whirlpool fridge with the same problem. The problem I believe is due to the drain line to the tray that collects defrost water freezing up. Temporary solution is defrosting the fridge; permanent solution is running a thin wire thru the drain line that aparently prevents the condensing water from freezing. I am trying to find out how to install this wire and where to buy it.
Jan 28, 2010 | Whirlpool Refrigerators
Ice maker not working; water in door fine. water not getting to the mold
The problem may just be the water control valne for the ice maker side is defective. I will return with part numbers and I would like you to fill the ice maker with water and let it freeze. If the ice dumps then we will know it is the water control valve, Sea Breeze
Oct 21, 2009 | Whirlpool EL02CCXP Compact Refrigerator...
Freezer runs constantly and ices up
It sounds like the thermostat has failed. Have it replaced and it should take care of your problem. Hope this helps, good luck!
Sep 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator is warm on the inside
hello mam
if the refrigerator is not cooling we should check the freezing coolant in the compressor and if necessary that should be refilled.
Jul 13, 2009 | Danby Compact Refrigerator DCR-101W
Ice maker freezing up
its a confirm defrost timer problem.the defrost timer is a device which after every interval of 8 hours defrosts the freezer part if the timer is faulty it wont defrost and go on over freezing.you can buy the defrost timer for aprox 30 dollars from link below:http://www.repairclinic.com/thanks and plse do not forget to rate the solution.
Jun 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My roper refrigerator(2door)constatly freezes up--WHIRLPOOL PROD.
Check the defrost timer, mark it and see if the dial rotates. It takes a while to see if it moves. Make sure food in the freezer is not blocking the openings for air to move around.
May 04, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Sound of Water coming from internal backside of freeze
Your unit was in defrost mode (happens once a day) and ice that built up over the previous 24 hours was melting and draining down a drain line to a pan under the unit so it will evaporate. This is how freezers stay " Frost free ". The water in the pan under the unit will evaporate by itself. Have a great day!
barneyluc
Oct 10, 2008 | Whirlpool ARG930 Compact Refrigerator
Kitchen Appliances - Others Logo
295 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
