This question is regarding MY WHIRLPOOL QUIET PARTNER II. The light above the Start button is flashing along with a solid green light next to the lock picture. I can not clear this error to run a load of dishes. thx Paul
If pushing and holding the lock button till the light goes out doesn't work, you likely have a problem on the circuit board.
Posted on Jun 09, 2014
SOURCE: whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Posted on Jan 22, 2009
SOURCE: Whirlpool Quiet Partner 980
clean light blinkin???? ry pushing the sanirinse-heated dry--sanirinse--heated dry. tha tshould put in diagnostic mode, there also should be a trouble shooter underthe lower acess panel
Posted on Apr 09, 2008
SOURCE: whirlpool gold- quiet partner III
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Posted on Oct 13, 2008
SOURCE: RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Posted on Mar 22, 2009
SOURCE: clean light is flashing
This can be a common issue with some Whirlpool manufactured dishwashers. This information may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Nov 02, 2009
Testimonial: "Worked perfectly! Thank you."
Apr 03, 2016 | Whirlpool Dishwashers
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Mar 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Jun 21, 2009 | Whirlpool Dishwashers
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Apr 09, 2008 | Dishwashers
Jan 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
740 people viewed this question
