Question about JVC HD-52G786 52" Rear Projection HDTV
How check sound boar on hd 52g786 - JVC HD-52G786 52" Rear Projection HDTV
2 Related Answers
Cindy Jarvis
SOURCE: My JVC TV model number HD-52G786 has no sound
Posted on Nov 28, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: I have a JVC HD-52G786
I presume you have no sound via the a/v inputs as well as cable or coax input.
We do factory work for many brands including JVC.
I remember one of these sets only a few months old with no audio, JVC exchanged it as the customer was angry (understandable). Ten minutes later we get a email and a call from JVC telling us set has been exchanged and they do NOT want the old one back---do whatever we want with it.
I had tested the set, following the audio circuit to a single board that supplies all audio--board was not real easy to get at and was on "backorder" meaning lots of them were bad and JVC was out.(which is why the set got exchanged).
I had the board ordered and about ten days later the replacement arrived--installed it (it was sandwiched between two other boards) and set worked perfectly===we ended up with a nearly new set (board wholesaled for about 80 dollars) and sold the set used with an extended warranty.
My point is if no audio from tuner or rear inputs it is a shop repair as most shops will not tackle this problem in this set IN THE HOME..
If you have audio from ANY input it may not be the set.
Let me know if you have questions, I am here to help you.
Regards, SD TECH
Posted on Jun 07, 2011
THERE IS NO SOUND
Try a hard reset by unplugging the set for 30 secs. Then, go into the remote and make sure speakers have not been turned off.
Apr 20, 2014 | JVC HD-52G786 52" Rear Projection HDTV
Can't get volume on jvc hd 52g786
This set is prone to the audio board inside failing---all the audio is on one board, last one I replaced was just over 100 dollars.
Oct 30, 2012 | JVC HD-52G786 52" Rear Projection HDTV
No sound
I have seen several of these (some brand new) where the audio board fails, if I remember it wholesales for just under 100 but is not real easy to get at---entire audio circuit is on it.
Oct 25, 2012 | JVC HD-52G786 52" Rear Projection HDTV
My jvc hd-52g786 does not recognize the remote. What do I replace?
The set has a receiver inside that the remote transmits a infrared signal to--if remotes known to be good do not work on set the receiver is bad.
May 28, 2012 | JVC HD-52G786 52" Rear Projection HDTV
No sound trough the tv speakers on JVC model 52G786
either speakers turned off, or an audio problem which was common on this model----the entire audio circuit is on one board which may still be available.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
My jvc HD-52G786 TV channel will freeze then
most likley you need to see ure dealer about that as it cost to buy the program and the cord just to do an update every 2yrs
Apr 27, 2010 | Televison & Video
HD 52g786 television was just moved from VA to CO. On arrival, the video works fine but no longer can hear any audio. Any suggestions?
Vibrations from moving often cause solder connections to fail. Check with a magnifying glass the solder connections on the PC board on the audio output chip for hairline cracks and resolder. If you are not profeicent soldering PC boards refer to a professional.
Oct 13, 2009 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-52G786
you will need to have a tech come out to do a convergence( replace chips and resistors)they control the vertical , horizontal and color alignment
electech
Oct 31, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Hd-52g887
How do you know the bulb is fine? Are the LEDs blinking together or alternating?
Apr 14, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-52G786 52" Rear Projection HDTV Logo
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
