SOURCE: my candy civ60 dryer dose not heat
hi i too had that problem,when an engineer looked at it the thermostat,element were ok,he suggested that there was a blockage in the air flow,i took the whole thing apart ( i had nothing to lose ) cleaned it with a hoover very carefully then with a clean dry paintbrush,there is vents underneath the dryer if these get blocked the dryer blows cold air, its a saftey measure so that the fluff dosent catch fire ! i hope this helps,mine has run ok for 3 months now.
SOURCE: changing belt on my dryer
I am not familiar with this particular dryer, but all electric dryers are designed so that the consumer can replace the belt. Open the access door ( the back, the top, or the removable panel at the bottom front) and the belt should be visible; a few minutes of study will show you what you need to do to change it.
SOURCE: cannot get into back of tumble dryer to fit new belt
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
SOURCE: I have a Candy Grand 8g vented tumble dryer. No
Its a wierd coincedence I have the exact same problem this morning,and my identical unit is 6 months old.Misery loves company,I will read the on line fault finder manual for this unit and hopefully find an answer
Regards Quiggers in Ireland
SOURCE: how to clean a whirlpool awz7913 condenser tumble
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
