Question about Ovens
My leisure GRB6CVK electric oven(main oven) has stop heating up. Fan and light works but no heat. Help pls. Any thoughts. Sheryl
Posted by sheryl on
ronandchi
    New Friend:
  • 36 Answers
Unplug stove and take wires off element. test for continuity on the poles. Also check wire ends.
Posted on May 24, 2014
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: main oven not heating up
fan oven element has gone. it is a circular element and is located behind the back panel of the oven. some elements can be removed with the oven in place but for many you have to take the oven out and take off the rear casing. whichever, it is not a difficult job. element cost about £30
Posted on Mar 29, 2007
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Posted on Dec 27, 2008
Anonymous
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
Anonymous
  • 12 Answers
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Posted on Oct 24, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: The main oven has stopped working, the fan comes
You need to fit a new fan oven element, located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Posted on Nov 29, 2009
Have Ck90g232 model,electric oven has no heat,the fan still works but not the light. All other ovens and hobs are functioning,is this an element issue and will a professional have to fix the problem?
The light may just be a burned out light bulb. Remove it and take it to an appliance store to find a replacement. As far as the oven goes, elements do burn out. They are relatively inexpensive. Make sure you have turned the oven OFF before you do anything. The heating elements do pull out and you can replace them yourself. Take the information about your oven and the heating element to an appliance store for a direct replacement.
Nov 15, 2017 | Ovens Ovens
AEG double oven/grill stopped working
It appears the oven has shorted out. Try checking the breaker box and see if any switches have been flipped. If this is not the case a new oven is in order.
Jan 24, 2014 | Ovens
U1442 main oven not heating
If you are sure there is 220v going to unit, it most likely is element or click / control. If you have a ohms meter, you can test the element
Sep 07, 2017 | Neff U1721 Double circotherm Electric Oven
My main oven will not heat up but the fan is working and the light works
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 [
Jul 25, 2011 | AEG U7101-4 Electric Double Oven
Oven fan not working so oven not heating up
have the motor checked and replaced if no runnig the oven will not heat as it is a safty measure
on moter the fan blade could have been loose, the motor bearings could be worn out or the fan motor gone kaput
Jun 15, 2010 | Zanussi ZBQ665 Electric Single Oven
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
AEG B2100 Not heating up - light does not turn on
Main selector switch may have burned contacts.
Nov 07, 2007 | AEG B2100-4 Electric Single Oven
Ovens Logo
63 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
