Question about Nokia 2630 Cell Phone (Unlocked) - Black
Sir i have nokia 2630 phone i forget my restorefactor setting my friend changing for defult 12345 code my friend changing for new password i con't finout plz help me IMEI : 359305/02/59923/7
Posted by TAMILARASU on
IT Solution
  • Nokia Master
  • 805 Answers
Dear,
You have to connect your phone with the pc and need a flash box then from there you can default your restore factory code which is 12345.If you haven't then please go to any mobile servicing center then asked them to restore your factory code. Thanks
Posted on Jun 15, 2014
5 Related Answers
SOURCE: Reset Security Code for Nokia 2630
here is the code to reset your security code ....
(this works only if 352929023505559 this is the correct imei :
*#6766336333#
this works for 99% sure ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Posted on Jul 10, 2008
Anonymous
SOURCE: nokia 2630 security code unlock
please help me to unlock my nokia 2630,i forget the puk code of my unit.
Posted on Oct 26, 2008
Anonymous
  • 34 Answers
http://www.askstudent.com/hacking/how-to-unlock-any-nokia-based-cell-phone-and-get-its-unlock-codes-absolutely-free/
Posted on Jan 02, 2009
Anonymous
I got a Nokia 6230,i never change security code,but now it will not accept my code,can you help
Posted on Jan 23, 2009
Anonymous
  • 544 Answers
SOURCE: Nokia 2630 Security Code Forget
thank you for choosing Fixya.com
please link to this site and you will directly connected to Nokia secret codes site please follow the instruction very carefully enjoy.
http://gleez.com/articles/did-you-know/nokia-secret-codes
please don't forget to rate our answers properly.
Posted on Mar 02, 2009
Sir,i have nokia 2630 phone i forget my restorefactor setting plz help me....... IMEI : 359305/02/599423/7
Dear, your default code is 12345 but if you change then the way is use the flash box which is connected through your PC and then make is default code. Have a enjoy. Thanks
May 24, 2014 | Nokia 2630 Cell Phone (Unlocked) - Black
Forget my nokia 2630 sacurity password plz help me
The default Nokia security code is 12345 unless it was changed.
Sep 06, 2011 | Nokia 2630 Cell Phone (Unlocked) - Black
HOW TO UNLOCK SECURITY CODE OF NOKIA 2690
Hello Amit,
Switch off the Nokia 2690 Cell Phone. Remove the battery for 30 minutes. Reinsert the battery and switch on the Nokia 2690 Cell Phone. Enter the default code 12345 or 00000. Your Nokia 2690 Cell Phone will be unlocked.
Jun 05, 2011 | Nokia 2690 Cell Phone
Hello sir. i forget my nokia 3110c phone security password as i change the sim card its asking for password which i have forget..so pls help me to unlock the phone
sir, all you have to do is.....after you inserted the new sim card and if it is asking for a code try to use the default security code 12345.... and if it will error code... go to the nearest cellphone laboratory and have it fix... they can fix it by restore factory settings using some gadgets....
Feb 02, 2011 | Nokia 3110 Cellular Phone
Hi.... i am using nokia 2690 how to lock the cell with password ???? plz guide me sir :(
Select Menu > Settings > Security and from the following options:
  • PIN code request or UPIN code request-to set the phone to ask for your PIN or UPIN code every time the phone is switched on. Some SIM cards do not allow the code request to be turned off.
  • Security level > Phone-to set the phone to ask for the security code whenever a new SIM card is inserted into the phone. If you select Memory, the phone asks for the security code when the SIM card memory is selected, and you want to change the memory in use.
  • Access codes-to change the security code (default code is 12345), PIN code, PIN2 code, or restriction password.
Jan 16, 2011 | Nokia 2630 Cell Phone (Unlocked) - Black
How to recover the password without fomating
Lost my security code.Urgent to use my Nokia 2630.HELP ME
Nov 28, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
Nokia 2630 Code Forget
Hi Friend,
From the below link uchange the security code by providing your IMEI number,to get theIMEI number u must just*#06# or at back side of the mobile u willhave serial numberis as same as IMEI Number,
http://mastercode.nokiafree.org/
or try this code for your imei number
0235557231
Regards,
Ayyasam
Jun 25, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
Unlock nokia 2630
nokia 2630
type:RM-298
IMEI:359559/01/675804/9
Mar 12, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
*#6766336333#
thank you
bye
rate my solution
Jul 10, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Nokia 2630 Cell Phone (Unlocked) - Black Logo
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
