Question about JVC HD-52G786 52" Rear Projection HDTV
Why does my jvc 5 inc tv have a big dark spot on the left side of the screen
Recently changed the bulb in my tv but it has a big dark spot on the left side of the screen. Do you know what this can be?
4 Related Answers
wjurls
  • 14 Answers
SOURCE: Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
Posted on Dec 29, 2008
Anonymous
  • 5 Answers
The gray spots are caused by dust on your lens, very easy to clean.
Power down the TV.
If you open the right side access panel (right side as you are looking at the front of the TV) you can see it in the middle, it's not very big. Using a scratch/lint free cloth, gently wipe off the lens or use a vacuum to **** up the dust being careful not to actually touch the lens.
Replace the access panel and enjoy your spot free screen.
Posted on Aug 12, 2009
Chi Chu
  • 8457 Answers
SOURCE: Hi I have a JVC DLP HDtv that uses a Bulb JVC CL11...
It not the bulb,it still good.Ur tv have a problems known as convergence,"have colors shadows,colors misalinement,picture look like 3D" it dead.This convergence problems it happen to all DLP TVS sooner or later. The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts in the convergence board must be change to fix this.The shop will cost u $300-350 for parts and labors.
Posted on May 23, 2010
DrewPalmer04
Andrew P.
  • 325 Answers
SOURCE: I have a JVC HD-ILA
I only have bad news for you. This tv uses an engine assembly. It is impossible to replace the color wheel only. The entire assembly is quite expensive and wouldn't be worth replacing for a tv of that age. (By expensive, I mean roughly $400-$600, before labor). To replace the assembly the tv is basically broken completely down for this repair too and thus very expensive for labor as well.
Sorry for the bad news, but with no warranty you seem to be out of options. Some people choose to just live with the color issues, while saving for a new tv.
Thank you and have a nice day! :)
Please rate
Posted on Apr 06, 2011
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
Jan 10, 2016 | JVC Televison & Video
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
I just replaced bulb with new and after a day there is a dark spot on the screen
I have the same TV - I have a dark spot in the upper left hand corner. I have always thought this TV was dark. Be sure to get OME lamp. Cheaper ones are not worth it and can damage your TV more.
dlplampsource,com--Just a note if this ever happens to you. TV would not come on in the AM-Had no picture, but had sound. It was not the lamp, but the safety switch. It's blue and at the bottom of the lamp housing. As soon as I flipped it and replaced the back cover, the TV came on.
Dec 22, 2012 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Recently the left side of the screen is dark (about 4 inches). I put in a new bulb but the dark spot remains. Is this fixable?
Sounds like a classic "Light Tunnel" defect. This part can be replaced in pieces, but can be tricky. I would not advise attempting this, rather for a DiY you should replace the entire Light Engine. The PN will depend on your Service Model # ...WX or WAX... and the version Id #.
Mar 13, 2010 | Samsung HL-R6167W 61" HDTV
Jvc 52z575 dark TV
The life estimate for a bulb is about 5000 hours, and if the bulb is dieing before that is very obvious you have another issue on the TV
That Could be a temperature problem, like a cooling system is failing (usually the is two fan around that) or a lot of dust in the cooling system. another one could be temp sensor also maybe failing and is not sensing high temperatures and is no turning off the TV
Also make sure you have enough ventilation in the back of the TV
Hope this give you a better idea of the problem
thanks
Apr 23, 2009 | JVC AV-48WP30 48" Rear Projection...
Oct 16, 2008 | JVC HD-56FN97 56" Television
Power down the TV.
Sep 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-56G886 56INCH REAR PROJECTION TV
I fixed it!!!! If you can open one of the sides (on the JVC there is a little door with a screw), then you can clean the projector lense in the middle on the bottom. It kind of looks like a big light bulb. It seems there is just dust on the glass that is projected onto the screen. We had a big gray spot and cleaned it with a damp glass cloth and Ouila! It disappeared. I scored MAJOR brownie points with my husband for this one! He wanted to replace the TV!
Sep 25, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Dark Blotches
This is probably caused by dust, either on the mirror, lens, or possibly inside the light engine. There is a 5" dia hole on the side of the back of the tv where you can take out one screw and take the door off. this is just big enough for you to put your hand through to clean the mirror and lens. Hope this helps.
Mar 30, 2008 | JVC HD-61FN97 61" Television
JVC HD-52G786 52" Rear Projection HDTV Logo
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
