SOURCE: do not work the clear storage tool to hard reset.
format your pda and reinstall the os and this will solve your problem
all the best
SOURCE: i am having problm in
By a hard reset I presume you mean resetting to manufacturers default settings?
If you can boot your device, the easiest way is to go to Start > Settings > System Tab > Clear Storage.
If you cannot boot into Windows Mobile on your Orbit then the best way is to hold down both the left and the right soft-keys (the two keys with _ marked on them, either side of the wheel) at the same time whilst you poke a paperclip (or similar pointed item) into the reset button on the left side of the orbit. This will initiate a hard reset on the device.
SOURCE: TOUCH SCREEN VERY SLOW OR DOES NOT WORK AT ALL
hi
If you have already test the alignment of the screen and still the
same, I suggest you bring your xda to a service center to check further
the software and hardware of it.
thank u
rate me!!
SOURCE: Cannot hard reset XDA orbit - Forgot password
To perform a hard reset
1.Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom center part of your device.
2.Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: "Press SEND to restore factory default, press END to quit."
3.Press on your device.
On my XDA the reset button is located on the left bottom side of the XDA.
