The best way to patch a hole when you don't have backing material is as follows:
Step 1: Cut the hole out square with a keyhole saw or utility knife:
www.all-wall.com/s.nl/sc.11/.f?search=keyhole+saw
Step 2: Cut a piece of drywall, (the same thickness as the wall that you are working on), to fit fairly tightly into square hole.
(HINT: You don't want the patch to fit so tight that it breaks the corners when you try to put it in.) If done properly, this patch will not want to stay in the hole by itself. You must leave 1/32nd of an inch all the way around the patch. Once the patch has been properly fitted, you are now ready to start taping it in.
Step 3: Put the patch face down on the floor or table so that you can easily work on it. Using drywall mud/compound & the 5" knife, lightly mud the back side of the patch (
www.all-wall.com/Categories/Joint-Knives/Hyde-Stainless-Hammer-Head). Place a piece of drywall tape over the patch, allowing it to hang over the edge of the patch about 1 1/2" on the top/bottom of the patch (
paper tape flaps).(
www.tooldistrict.com/2inx500ftpaperjointtapepn500bypermaglas-mesh.aspx) Holding the tape firmly against the patch, wipe down the tape with the 5" knife.
Step 4: Once the piece of tape is wiped down, you are now ready to apply mud to the section of wall where the
paper tape flaps will be laying. Place the patch over the hole, tapping it into place until the patch is laying flat on the wall. Holding your fingers on the seams of the patch, wipe down the first paper flap, and then the other.
(HINT: Always wipe down the top flap first, then the bottom flap. Make sure the patch is flush with the wall, or recessed slightly. If the patch is sticking out from the wall even a little bit, it will be very difficult to hide!)Step 5: Now that the patch is in, mud the horizontal seams in, paper tape, and wipe down. Repeat the process for the vertical seams. (NOTE: You may use mesh tape on these seams if you wish because mesh is a little thinner than the paper tape; making it a little easier to cover on the next two coats. Don't make a special purchase if you don't already have some laying around, it's not worth it. (
www.all-wall.com/Categories/Fiberglass-Mesh-Drywall-Tape/Thin-Drywall-Mesh-Tape )Let this dry for 12 hours before coating again.
Step 6: For the next coat you will need a 10 " broad knife (
www.all-wall.com/Categories/Taping-Knives-Stainless-Steel/Hyde-Maxxgrip-Extruded-Back) Apply mud to the patch, covering the tape from the previous application.You will need to leave more mud around the outside of the patch; not too much on top of the tape. It is already going to be a little high on top of the tape so you are basically creating an optical illusion by building up around the patch. Let this coat dry 24 hours.
Step 7: If the 2nd coat was done properly, then putting a finish coat, (3rd and final coat), won't be a problem. This coat is just to fill in any low spots that you weren't able to get completely full the last coat. And if you did get it full the last time, congrats, then it is just a skim coat to fill in any air bubbles that may exist.
(NOTE: Whenever patching over an already painted wall, the drywall mud/compound will bubble. This is normal. After 2nd coat of mud drys, scrape off the air bubbles before applying the next coat.) Let this coat dry for 12-24 hours
Step 8: Now the fun part begins: Use a sanding sponge or a sanding pole to sand the patch off, (
http://www.all-wall.com/acatalog/A000_Dustless_Sanding_20.php). Then it is ready for paint!!
Good Luck!
If you should have any questions about"Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power-HAND TOOLS" at FixYa.com
I will do my best to answer your questions about drywall finishing, but as you can see, just a simple patch is very involved.
However, it would be best if we could speak on the PHONE or do a live CHAT. I can answer any question you have if it involves getting a wall ready for paint!
Jim
Key Words: Drywall/Sheetrock/Gypsum Wallboard, Patching, Texturing, Speckling, & Paper Tape
