Question about Bosch Axxis+ WFR 2460 Front Load Washer
Why does aeg lawamat not spin - Bosch Axxis+ WFR 2460 Front Load Washer
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
AEG Lavmat 835 washer will not reach spin speed
Possible fault in the motor , the bearings the drive belt or there is friction on the drive shaft.
Please check these links for tips:
Bearings check
Drive Belt
Jul 02, 2012 | AEG Lavamat 72640 Front Load Washer
My aeg washing machine has stopped spinning all the clothes are very wet
Hi.
Check if there is drain blockage. That will result in cycle not advancing to spin. To check drain system, check drain hose at the back and access drain filter in front.
If there is no drain problem, check pressure switch and lid switch.
Here a general article that I wrote about no-spin problem: If you have no spin ...
Regards.
Ginko
Apr 19, 2011 | AEG Washing Machines
Aeg 72630 won't spin
most likeley cause are worn out carbon brushes in the main motor. have you seen any error codes e52 relates to the motor brush problem. e20 is inefficent draining caused by blockage in the pump chamber acces in the plinth area/ or in hoses or drain connection
Jul 21, 2010 | AEG Washing Machines
I need a motherboard for a aeg lavamat l62622
I have an AEG WITH ERROR CODE C9 IT WONT SPIN OR WASH ,COUNTS DOWN THE CYCLE ,FILLS BUT CLOTHES ARE LEFT A STICKY MESS ,MOTOR AND BUSHES ARE FINE ,I HAVE RESET NUMEROUS TIMES BUT STILL GOES TO C9 ANY IDEAS
Feb 26, 2010 | AEG Washing Machines
Aeg dishwasher will not drain
The washer has a drain motor in line with the outlet pipe. The motor must turn when in outlet mode. This motor has an impeler that turns at high speed to pump out water in the outlet mode. The motor could be faulty or the lelectrical push on connectors to the motor loose. One can remove the motor and coonect it directly to the mains voltage for a few seconds to check if it spins (also make sure that nothing is blocking the impeler from spinning).
Oct 24, 2009 | AEG 24 in. Favorit 40630 Free-Standing...
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
Aeg oko lawamat
c9 means the motor is not turning the drum. check carbon brushes in the motor.
Oct 29, 2008 | AEG Lavamat 88840 Front Load Washer
Error 20 AEG washer dryer
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Jan 09, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
Top Bosch Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
