Good Morning Friend,
I understand that your Frigidaire washer, model# ATF6000ES, is agitating but not spinning the water out of your clothes. I suggest trying the following solutions:
1) Make sure you select the appropriate spin speed for the load.
2) Make sure you do not overload washer.
3) Make sure the load is not too small. Add 1 or 2 similar items to help balance the load.
4) Make sure the load is not out of balance. Rearrange load to allow proper spinning.
5) Make sure that the drain hose is not kinked. Straighten drain hose.
After checking the above, reset your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power has been restored run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: Frigidaire front loader
Can you hear the motor running? If so it will be the belt. If not simple could be the wiring..connection at the motor or broken wire. Brush's..very common at about 4-6 years depending on usage. or the controller.
SOURCE: Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
SOURCE: Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
