Question about Maytag MHWE200XW Washer
How to clean the drin filter
Removed bottom panel filter wont turn
David Morgan
    New Friend:
  • 5 Answers
If there is enough room put a large adjustable or water pump pliers on the cover,i used the adjustable and put a screwdriver through the hole in the end and very gently applied pressure until in moved, I sprayed a little lube in the space between the cover and housing and it came off much easier then. There was so much debris in the trap and it stinks really bad, a large dish is needed under the cover as a lot of water will come out. Clean out the trap and reassemble using vaseline or grease to help the o ring seal.
Posted on Jan 05, 2015
3helpful
2answers
Is there a filter on this model
Of course. The filter is located in the pump behind 'front' bottom panel. Disconnect power, remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the filter by turning the knob counterclockwise. Be prepared for a lot of water, catch it in something to prevent more work. Clean the filter from any debris that prevents water from draining out properly. Front loaders hv filters, top loaders don't. Don't forget to click that you are helped!
tip
Clean the pump filter screen on a Kenmore HE2 Not draining
  1. Unplug machine.
  2. Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
  3. Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...
  4. Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be careful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris.
  5. Once everything is cleaned out reverse removal procedures put back together.
Keeps coming up with f5 wont pump out or spin
You need to chjeck and clean the pump filter.
Remove rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble and test.
8helpful
Drain wont drain on a epic washer where is the drain filter located at
The drain filter is located in the pump behind front bottom panel. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly.
CLEAN PUMP LIGHT COMES ON WHERE IS THE PUMP LOCATED
The pump is located behind front bottom panel on the right side assuming that your machine is a Whirlpool or Kenmore Front-Loader. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
It wont pump out does it have a drain filter ??
The filter is located at the rear of the washer.
Remove rear panel, and remoive large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
A PEN WENT DOWN THE LINT TRAP AND NOW THE DRYER WONT TURN ON. KENMORE GAS DRYER
can you move the drum by hand?if not the pen is jammed in the blower wheel stopping the motor from turning,if the filter is on top you'll need to remove the filter,take out the 2 screws in front of the filter now make sure the dryer is on a flex line so you can pull it forward to remove the lint filter and then remove the back panel,now you need to remove the 4 screws holding the duct on that the filter slides into and remove the pen and any lint that's in the duct,if the filter is inside remove the bottom panel,remove the filter and take off the duct and clean it out,next time send model number
1helpful
My washing machine wont spin or empty
You need to clean the filter.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Please rate my solution.
Thankyou.
1helpful
Wont wash keeps flashing prewash
Check pump filter.
Remove lower rear panel \of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose..
Remove hose onto pump, and check for blockage and obstruction here as well.
Hope this helps.
2answers
Wont empty water cant find filter
Remove 3 screws from the bottom front service panel. Pull the panel down...then off. The pump will be in front of you.
Maytag MHWE200XW Washer Logo
Top Maytag Washing Machines Experts
Jessie Goss
Sheldon Dedek
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
