Dishwashers Logo
Question about Meiko FV 40.2 Dishwasher
Keep getting error 202 just replaced the booster rinse motor and the heating elements meiko dishwasher
Posted by clintkass on
Anonymous
    New Friend:
  • 70 Answers
It's inlet water not sufficient. 1)check inlet water is entering in to machine. 2)may be inlet water solenoid defective. 3)check the rinse water pump is working.
Posted on Aug 27, 2010
1helpful
Meiko dish washer Temperature fault rinse error
If you are still experiencing the H0005 temperature fault alarm on your Meiko dishwasher after replacing the PT100 sensors, there may be a problem with the dishwasher's control panel or other internal components.
Some potential causes for this problem include:
  • The control panel may be faulty. If the control panel is not functioning properly, it may not be able to read the temperature sensors correctly and generate the H0005 error.
  • The wiring for the temperature sensors may be damaged or disconnected. Check the wiring to ensure it is secure and in good condition.
  • The dishwasher's heating element or other internal components may be faulty. If the heating element or other components are not functioning properly, the dishwasher may not be able to maintain the correct temperature during the rinse cycle.
If you are unsure how to check for and address these potential causes, you may want to consult the user manual for your Meiko dishwasher or contact the manufacturer for assistance.
Meiko dishwasher model 80.2 showing error 204 when water filling to the tank, give me the solutions..
This is straight from the repair manual.
204 Final rinse time Parameter 4 ... 30 s. 7 Duration of booster pump activation (running time limited by P306!!).
306 Maximum final rinse time Parameter 0 ... 30 sec. Maximum booster pump running time (rinse) (limit of P204)
Booster heater pump does not work Check power supply to power rinse pump. Check pump rotor and replace 203/204 pump if necessary. Check start capacitor and replace if necessary.
Hope this is of some help.
Meiko FV40.2 Error 305?
Booster pump output low/defective, rinse nozzles clogged, wash tank level sensor soiled, moisture in sensor tube, hose kinked or not water tight
booster tank level sensor defective/disconnected, water inlet strainer is soiled, booster tank vent is clogged, anti siphen flap
This is per their tech manual.
I have found in some cases that the impeller on the fill motor is plastic and can become disconnected from the motor shaft.
Meiko dishwasher DVD 80.2 showing error 202
202 Level not reached in booster tank during filling.
Level switch defective/disconnected, water turned off, inlet hose kinked, inlet strainer clogged.
Start with these basics.
Meiko error 203
203 No change detected by level switch during rinse pump operation
Level switch defective/disconnected, booster pump defective/disconnected, start cap defective/disconnected, no signal from I/O board, check microswitch manually.
This is per their service manual.
Error codes 206
206 Increase in wash time Booster not ready for rinsing at right time. See error code 205.
205 Temperature increase not reached Booster heater not working, heat elements are open, defective temp sensor.
Per the service manual
MEIKO DV 80.2 ERROR CODE 305
305 Booster content is insufficient for rinsing
See error code 301, booster tank level sensor defective/disconnected, water inlet strainer is soiled, booster tank vent is clogged, anti siphen flap.
301 Level 1 not reached when filling (number of cycles exceeded)
Booster pump output low/defective, rinse nozzles clogged, wash tank level sensor soiled, moisture in sensor tube, hose kinked or not water tight.
1helpful
Why rinse booster heater and rinse cycle not function for MEIKO-Model: DV80T (Dishwasher)
In these machine when boiler heating not reached to 85 deg 1)washing cycle keeps running. 2)it will not goto rinse cycle. 3)check the boiler heater & replace.
1helpful
What does error code 205 mean on the Meiko FV40.2
This error code means your booster heater is not getting up to the proper temperature. You can check your amp draw across your booster heating element to verify it is in fact heating and not blown. Also, check your temp sensor for resistance. At room temperature, you should read about 1000 Ohms. At 180 degrees, you will read about 1500 Ohms.
4helpful
5answers
Error Message coming up
Hi, i work on these machines on a regular basis and until very recently i was a Meiko service engineer- the code ERR203 means that there was no change detected at the boiler level switch during emptying- be it on the fill or rinse cycle. This fault is mostly caused by the booster pump failing to pull water but could also be caused by blocked rinse jets or a faulty boiler level switch. Hope this info is of use to you , Kitcheneer
Top Meiko Dishwashers Experts
spz1
Level 1 Expert
Marvin
Marvin
Tom Chichester
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
