Question about Realspace Magellan Collection L-Shaped Desk, 30in.H x 58 3/4in.W x 58 3/4in.D, Espresso
Paper vaneer damage - Realspace Magellan Collection L-Shaped Desk, 30in.H x 58 3/4in.W x 58 3/4in.D, Espresso
Why hp printer will not load paper
Possible causes for your problem according to HP official website:
  • Manual feed mode is turned on.
  • The paper tray is empty.
  • The paper length guide in the main input tray is not snug against the paper.
  • The pickup roller might be dirty or damaged.
  • The paper is wrinkled, folded, damaged, or has ragged edges.
  • The paper is too moist, too rough, too heavy, or too smooth.
  • The paper has the wrong grain direction, is of short-grain construction, is embossed, or is from a faulty paper lot
Try downloading user manual and see if there are any troubleshooting options Download Free Manuals
Dec 31, 2015 | HP OfficeJet Office Equipment & Supplies
What would cause paper jams in a hp 4100 printer
Where is it jamming. Printer this age could have fuser issues, worn rollers that are not picking up properly. Is the jammed paper crinkled up or does the printer stop before damaging the paper? If paper is not damaged, the cause is usually in the paper pickup slipping and causing the printer to think that the paper is either too long or too short. Clean all the rollers in the paper tray cavity with a damp cloth.
Sep 05, 2014 | HP LaserJet 4100 Printer
My HP Laserjet 1012 stopped feeding paper, and my Mac printer dialogue box says: "the paper tray needs to be filled." It has paper. I have removed and replaced the paper several times, and opened up and...
The printer has a sensor that sees if the paper tray has paper in it, frequently by means of a finger that drops onto the surface of the paper. If this has been damaged, the problem you describe will be experienced.
Check to see if the sensor has been damaged.
Dec 10, 2013 | HP LaserJet 1012 Printer
Printer says that paper is stuck, but there is no paper.
These printers use sensors to track the paper, if one is damaged it will declair a paper jam, look for damaged sensors/switcher in the paper path,
May 13, 2012 | HP Officejet 5610 All-In-One InkJet...
201.08 paper jam The paper continually jams - I clear it and hit the continue but it jams over and over. there is nothing stuck in there!!
201.08
Description
Exit sensor is never made.
Possible causes:
• Improper loading of manual feed slot
• Paper wrapped in fuser
• Damaged paper exit sensor or paper exit sensor flag
• Damaged fuser autoconnect
• Faulty fuser DC cable connection
• Faulty fuser
• Faulty system card
Action
• Check for anything in the paper path that might cause the paper to jam.
• Load paper in the manual feed slot.
• The fuser exit sensor may not be functioning properly.
Jul 14, 2011 | Lexmark C530dn Laser Printer
How do I clear a paper Jam
Try either of the following methods to clear the paper jam. The operator panel displays the Ready message when the jam is cleared.Method A:
  1. Press Paper Rewind until the Paper Empty message appears.
  2. Press Paper Advance to re-load the paper into the printer.
    The printer advances the paper, then cuts and discharges about 24 in. (61 cm) of blank paper. This reduces the possibility of fingerprints or other damage to the prints.
Method B:
  1. Turn off the printer and open the upper cover.
  2. Remove the ribbon from the printer.
    Caution: Prevent damage to the printer. Do not pull abruptly on the paper.
  3. Slowly and carefully pull the jammed paper out of the printer.
  4. Cut off any damaged or printed areas of the paper. Do not damage or mark any of the rollers.
  5. Close the upper cover and turn on the printer.
  6. Press Paper Rewind to rewind the paper into the printer.
    Note: If the Paper Jam message still appears on the operator panel, press Paper Rewind again.
  7. Open the upper cover and reload the ribbon.
  8. Close the cover.
  9. Reload the paper.
Note: If the Paper Jam message still displays on the operator panel, and you are at the end of a paper roll, it is possible that a segment of paper is too short to automatically exit the printer. Remove the front cleaning roller and remove the segment of paper.
Jan 03, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Tray is not feeding paper properly. Its making a weird clicking noise when paper is being fed. Paper gets jammed on most attempts.
Remove the paper tray and try to see some paper jammed somewhere around it. When pulling off paper jam. Just pull gently and slowly so that you can remove all and nothing left behind and doesn't damage the part when removing unwanted paper jam. Maybe it is the cartridge just repalce new cartridge if not the fuser drum maybe damage.
Dec 08, 2010 | Brother MFC-7820N Printer
The T642 jams constantly under the toner cartridge when printing from the manual tray.
Hi, Make sure you have all of your paper settings properly configured in the Paper Menu of the printer. Paper size, type and weight. Then make sure there is nothing blocking the path of the paper as it enters the printer. That will be easy to notice since if there was and obstruction the paper will get damaged. If there is nothing in the paper path then the printer must be giving you an error. If its a 201 then the input sensor(little plastic flag under the toner) could be damaged. If it gives you a 202 then maybe the fuser exit sensor is damaged. In that case you will have to contact Lexmark's tech support so that you can get help if your printer is still under warranty.
Dec 14, 2009 | Lexmark T642 Laser Printer
I have a Sharp AL-1661CS copier fax machine and the paper is getting stuck when we try faxing. Paper goes 3/4 of the way thru and then gets stuck. Help
If there is lead edge damage on the original, open up the feeder section and line up the damage with the paper path. look for foreign objects or damaged guides.
If there is no damage clean the rollers with alcohol. and the sensors with compressed air.(Computer Duster) Try it again.
Hope this is of some help.
ed
May 05, 2009 | Sharp AL-1661CS Laser Digital Copier
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Realspace Magellan Collection L-Shaped Desk, 30in.H x 58 3/4in.W x 58 3/4in.D, Espresso Logo
Top Realspace Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Realspace Computer and Internet Expert? Answer questions, earn points and help others
