Does the dhcp on my tv need to be on or off. Can't stream from the internet either way.
SOURCE: trying to connect to Netflix
Adjust the NAT firewall on the router to open a port or two for Netflix to stream.
SOURCE: Just purchased a Vizio 37" HDTV with Netflix app
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: router is connecting my computer - want to stream
It seems that the wireless connection between the router and the ROKU is broken due to which you are not able to see the video. i am not sure about the settings of the ROKU but if you want then i can take the remote access of your computer and try checking the configuration of your router and roku (if possible)
For further assistance, log on to HNetworking.com or call us @ 859 309 7078
Admin
HNetworking.com
SOURCE: Belkin g mimo router blocking netflix streaming
There is not much protection you will be getting from the firewall of that router. You could let it be disabled and if you feel that the router firewall should be enabled then you might have to check if there is any firewall update for this product. You could log on to.. http://www.belkin.com/support and enter your product details including the version number you will be able to download the firmware.
Hope this helped.
SOURCE: i'm trying to connect to
Connect your wii using a Ethernet cable from the Ethernet port on the back of your wii to the router, or connect the wii using wifi.
The wii t your tv as usual and that's it.
