SOURCE: radio has sound but not the CD player or iPod
Your amp is not turning on - what you should do is connect the "blue/white - remote turn-on lead" to whatever wire you have the "blue - power antenna" output from the Alpine connected to now. That should solve your problem.
SOURCE: 2003 Ford Focus Blaupunkt Cd Player issue!!!!
I hav an 03 and it exhibited the same problems; on off on off nothing works. I discovered this repair 2 days ago and it works perfectly and I am one happy camper.
1. Start by pulling the main fuse for the radio (if you already haven't)
2. Re insert the fuse and turn the radio on (nevermind the on off sequence). Insert a music CD, it will take one.
3. Pull the fuse again, count to five and re insert fuse.
4. When the CD starts to play, use the menus to get down to the factory default settings and ask it to reset to factory.
5. And you are now working again. Or you should be. It basically is a processor and it operates just like your home PC whn it needs a reload. It searchs to the default drive which is the CD player.
Good Luck everyone!
SOURCE: Radio code not working for 6000 cd rds eon
look in boot left hand side and you will with any luck find the radio code stuck on a sticker
SOURCE: BLAUPUNKT GMDAT CDP 3 (E) - CAR RADIO CD HOW TO EJECT CD?
Hi graz,
If your unit has a SRC button to the right of the CD clot, try holding this down for a few seconds - works on mine!
SOURCE: My car radio is locked it is a Ford Icon radio make is 6000CD RDS
i need unlock key code for 6000 rds cd radio
