Brushes won't run. Reset button doesn't work.
Sounds like 1 of 4 possibilities
1.The button next to your on switch is jammed.
2. The Motor has burnt out within the head unit
3. The PCB Unit is faulty wihin the head unit
4. The thin wires running down the inside of the machine to the head unit hve br
Hi Frank, it's Jack at Dyson.
I'm sorry to hear you're having difficulty resetting your DC18's brush bar. The video attached shows the correct way to do this - after removing any obstructions from the cleaner head and brush bar, the reset button should reset the machine. Please note, it's important to recline your machine into the normal vacuuming position before testing it - the brush bar will never rotate when the machine is standing upright.
It's also worth ensuring the brush control button is set correctly - with the vacuum turned on and reclined into the vacuuming position, try pressing this button twice.
If you'd like some further advice from our experts after giving this a try, please give us a call. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
