Question about Fellowes Office Equipment & Supplies
Can you take apart a fellowes PS-12C - Fellowes Office Equipment & Supplies
Posted by John Pallaria on
Big Steve
  • Fellowes Master
  • 1,087 Answers
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
Posted on May 25, 2014
Plastic stuck in my Fellowes shredder blades!
Sorry, but no. There isn't really a way, unless you are very technically minded, to take the teeth apart and clean them. You might try, using a paperclip, I find that I have to do that on occasion to clear out the pieces that get caught in between the teeth.
or maybe, just a thought,?... You can use a product called goof off, it does come in a aerosol can as well, in addition to small bottles of the product in liquid form. Good luck.
Ps-60 repairs
I own a Fellowes PS 60 shredder.
It could be that the sensor has trash or it is sensing something. Check it carefully if you see trash/debris cleanit with a Q-Tip or air blower - !DO NOT USE ANY WATER OR SOLVENT! -
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Red and green light is on but it wont shred
Wiring diagram for a Fellowes PS 60CC shredder
I DO NOT THINK THE LINK WILL HELP YOU, BUT AT LEAST YOU WILL HAVE IT.
When plugged in and turned on, both the red and green light come on and it does not work forward or in reverse
Broken off DB-0812D mini-transformer from PS 67Cs Fellowes shredder
Purchase a 220/240 volt to 15.6/15.6 volt transformer and run flying wires as it will probably be larger in physical size.
I used a M7230 from Aztronics/Altronics.
Silicon the transformer in place to stop it falling apart while in its place.
Fellowes Powershred PS 60CC stopped working
4helpful
My Fellowes ps-40 will not shred. The motor is
you have some shredded gears. i don't think fellows has replacement parts for their personal shredder line.
1helpful
Fellowes PS60 CC shredder jamming
You have guides or cutter assembly out of alignment. Take it apart and double check before reassembling.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Top Fellowes Office Equipment & Supplies Experts
David Shaub
George Mclaughlin
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
