Washing Machines Logo
J
Jennifer Dillan Posted on May 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gltf530dso frigidaire washer
How do I fix a broken paddle?
Steven Brandon
Level 3:
Master:
  • Master 462 Answers
  • Posted on May 23, 2014
Steven Brandon
Master
Level 3:
Master:
Answers
462
Questions
0
Helped
117676
Points
1705
Http://www.appliancepartspros.com/frigidaire-vane-131274600-ap2106479.html
This is the part. You have to remove all the panels, The drum counter weights and finally the drum. Then you have to remove the inner drum from the plastic outer drum. Once removed you can get to the screws that hold the paddles in place. Then put it all back together. It may be easier to call a repair man in your area.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
2 Related Answers
Anonymous
  • 2605 Answers
  • Posted on Apr 02, 2011
SOURCE: Hi: Frigidaire GLTF530DSO started
Hello, Welcome to FixYa. I suspect the rear bearing or spider gear is toast, thus the reason the shock absorbers where broke in the first place. Very common for these machines unfortunately. It is a very involved repair either way but if you think you're up to it ( plus, is it worth it ? Parts are in the range of $400-$500 ) I can help in whatever manner possible with those frigidaire washers. I'll watch for your reply. Good luck. Regards, Macmarkus :)
chrispolkele
Electrolux
  • 4342 Answers
  • Posted on Oct 25, 2012
Our people make the difference
    Verified Fixya Pro
    SOURCE: How do I remove the washer paddle on my frigidaire front load washer
    Hello - Generally speaking, there is not a paddle on a front load washer however there is a "vane" which is where the water comes out of. What issue is the unit experiencing exactly? Can you tell me if it is displaying any specific error codes? If I know more information on what the issue is, I can try to better assist you further.
    2helpful
    LG front load washer wd11029d drum paddle. Having trouble removing.
    The drum paddles are screwed from the outside of the bowl. To access them, you have to completely strip the machine and remove the wash bowl. The paddles are rarely available as a spare part. You may be able to repair it or remove it. This will affect the wash action to a certain extent if you take it out. Its a big job.
    Frigidaire Washer GLTF2940FS2 How do I remove & replace washer paddles
    Thank you for your inquiry, Dawn Leonard!
    From what you have described you want to remove your washer paddles and replace them on your Frigidaire washer. I am unsure which paddles you are referring too? Could you provide further information, please? With that I would be able to assist you further. -Matt
    Paddle in drum broke
    Hi friend, thank you for your post!
    Based off the information you have provided the paddle (vane) inside your Frigidaire washer broke. I would recommend having a technician come out to diagnose and repair your appliance due to some of these intricate parts requiring precision and patience. When replacing such components or removing them from your appliance I suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. Hope this helps. -Matt
    Ice Dispensing Paddle is Broken
    Not sure about the frigidaire,but most front panels can be removed from front. If you look around outer edge of trim piece there might be little screwdriver slot. Carefully pry off trim piece(faceplate),disconnect electrical plug on back,set aside.Once removed you should see you solution for removing paddle.
    How do i fix a paddle on the drum? I have zanussi machine. Paddle broken off. If i buy a new paddle how do i fix it on? Have tried to glue old paddle with no success!!
    With some of these machines now they have sealed drums.On some models you can access through the bottom sump hose and others you may be able to get access through the hose by the soap box.There are a couple of drums where you can drill a hole in the top to get at the tags on the paddles and some drums where you cannot do without changing the complete tub.
    Hope this helped.
    Broken water paddle
    remove the bottom pan by pulling it out, then you will see three screws. remove the screws. Push the fram up which will unlatch it. The asbly will now come out. pull the water hose and the electrical connector, and you'll see the screws that hold the paddle.
    Broken water paddle
    be sure to unplug the refrigerator.
    remove the drip tray by sliding it forward.. then remove two screws . slide the dispencer cover up two screw hold in the control remove water line two screws hold in water paddle. remove paddle and wire.
    to replace water line use a long screw driver to push back into cover. make sure it extends bellow outlet..
    hope it helps
    7helpful
    4answers
    Drum Paddle broken Hotpoint Aquarius
    How to fit Washing Machine Drum Paddle Lifter
    For all free video help on appliance Repairs visitour Video Tutorials
    Here's our video guide to replacing a washingmachine drum lifter.
    A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
    The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
    Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
    There are few types of drum lifter; drum Paddle lifters
    On hotpoint, creda, Ariston ,indersit and someother makes see video
    To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
    Huge selections of lifters are available on thewebsite DrumPaddle lifters
    3answers
    Top Washing Machines Experts
    john h
