Hyundai Tuscon 08 2008 Logo
Debbie Williamson Posted on May 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2008 hyundai santa fe 2.7 l belt diagram - Hyundai Tuscon 08 2008
Thomas Smithbrother
Level 3:
Top Expert:
  • Hyundai Master 3,698 Answers
  • Posted on May 23, 2014
Thomas Smithbrother
Hyundai Master
Level 3:
Top Expert:
Answers
3698
Questions
0
Helped
955880
Points
10318
Https://www.google.com/search?q=2008+hyundai+santa+fe+2.7+belt+diagram&oq=2008+hyundai+santa+fe+2.7++belt+diagram&aqs=chrome..69i57j0.11007j0j8&sourceid=chrome&es_sm=93&ie=UTF-8
1 Related Answer
Alan H
  • 139 Answers
  • Posted on Aug 22, 2012
SOURCE: 2.7 hyundai serpentine belt diagram
Belt routing diagram for vehicle with air conditioning:
Diagram for vehicle without air conditioning:
2009 Hyundai Santa Fe. I need dash harness colour codes please?
Edited the first part for clarity.
Hyundai Santa Fe SE 2009 - SYSTEM WIRING DIAGRAMS
https://portal-diagnostov.com > 2020/03/26 > radio-hyu...
Mar 26, 2020 - RADIO - Hyundai Santa Fe SE 2009 - SYSTEM WIRING DIAGRAMS Radio Wiring Diagram, with Amplifier & Rear Seat Entertainment (1 of 2).
Hyundai Santa Fe (2006-2012) EMP300RDS pinout
https://pinoutguide.com > ... > Hyundai Santa Fe pinouts
Dec 10, 2019 - Hyundai Santa Fe (2006-2012) EMP300RDS pinout ... Audio Head units > Hyundai Santa Fe pinouts · 24 pin Hyundai Head Unit connector layout
2009 Hyundai Santa Fe Radio Wiring Harnesses - Crutchfield
https://www.crutchfield.ca > ISEO-rgbtcspd > ymm > 2...
Need a radio wiring harness for your 2009 Hyundai Santa Fe? Get free shipping and free lifetime tech support with your order.
1helpful
Diagram for reconnecting vacuum lines on 2008 Hyundai Santa Fe
Nancy, There should be a vacuum hose diagram under the hood of your Sante Fe, either on the underside of hood or on the radiator support. Contact the dealer and they can print it off for you also.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
VACUUM HOSE V6 SOHC SONATA 91MY for 2004 Hyundai Santa Fe
How To Find Vacuum Leak EricTheCarGuy
2008 hyundai santa fe vacuum line routing Google Search
2answers
I need a diagram for the timing marks on a 2003 santa fe. Can you help me?
This is a common issue and the fix is on this site already. When this link:
Questions Answers for Hyundai Santa Fe timing marks diagram
Fuse box diagram for 2007 hyundai santa fe
On this website you find fuse box diagram and description for Hyundai Santa Fe
Hyundai Santa Fe 2007 2009 fuse box diagram Auto Genius
Serpentine belt replacement
The 2006 Santa Fe came with three (3) different engines, each having different serpentine belt arrangements. The 4cylinder 2.4 lit has three belts, the 2.7 has only one (1) drive belt, and the 3.5 lit has two (2). Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop manuals, service bulletins, illustrations and procedures, etc.
5helpful
Replace serpentine belet on 2002 santa fa
Below is the diagram you will need to replace the belt. The diagram is for a 6cyl. 2.7 engine (most common for that year). Once the tensioner pulley is loose, route the new belt as diagrammed and while applying pressure, tighten the tensioner pulley.
2002 Hyundai Santa Fe 2.7L with A/C
3helpful
Diagram for serpentine belt
For the 2004 Hyundai Santa Fe:
I do not know if you have the 2.4L DOHC In-Line 4-Cylinder, 2.7L DOHC V6, or the 3.5L DOHC V6 Engine; however the Link below has all three Diagrams.
Click on the following: direct, free Link. It has the Belt Diagrams for your 2004 Hyundai Santa Fe. It also has very helpful Instructions and Directional Diagrams.
Let me know if this helped...
http://www.2carpros.com/car_repair_information/year/2004/make/hyundai/model/santa_fe/2004_hyundai_santa_fe_drive_belt_routing_diagram.htm
Top Hyundai Car Audio & Video Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Hyundai Car Audio and Video Expert? Answer questions, earn points and help others
