Whirlpool washer LSR7233BQ0. Washer stops 1-3 times during normal wash cycle, for a minute or more, then continues. Sometimes, it does not do final drain and spin until we rotate control knob around and back to spin. Lid switch appears OK. Would replacing the timer fix it?
SOURCE: Whirlpool Washer wont spin or drain
check your run capicitor
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it. Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
SOURCE: washer will not drain water or go into rinse and spin cycle
First thin I would try is to check your thermal fuse for continuity.
Its located on the tunnel that incases the heasting element.
Try putting the machine into diagnostic mode. If it won't enter
diagnostic mode, then you need to replace the main control board.
You also want to check the drain hose, the end of the hose is tapperd
and tends to collect lint. Run a coat hanger up the hose and see if you
can fish something out also check that belt.
SOURCE: Problem with F21 code on whirlpool duet sport
i had the same problem. take the bottom cover off of the front of the washer. on the right you will see a round white screw off cover, it is very tight, it unscrews counter clock-wise. pull this out and see if there is any debris in it. if you look into the hole on the right side there is a hole about 1 inch round, this is the pump opening. you may have to take the gray drain hose off of the back of the pump housing and feel if anything is stuck in there, in my case there was a penny stuck side ways blocking the flow of water. after i took it out the washer has been running great again. this is obviously a design flaw, that something that large could manage to get that far, lucky for me it didn't damage the pump impeller. hope this helps. this should take care of the SD and the F21 error codes.
