Toshiba SD-V55HT System Logo
A
Anonymous Posted on May 23, 2014
I think my speaker is busted model v55htw sub woofer
Can i hook up my bose model ps38 powered sub to onkyo reciever
Why not. A speaker system should work with anything that produced sound meant for a speaker.
Don't you think?
find the woofer out on the onkyo and connect the bose sub-woofer there.
Seems pretty simple. If you don't think so, go hide in a closet.
NOW!
1helpful
Can I use my Logitech x-230 speakers without the sub-woofer? My sub-woofer got busted!! Any suggestions?Perfectly good speakers!
i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
1helpful
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
I have a JBL TLX CSS-SUB1 sub at the back are where you connect the speaker wires to the receiver but i don't know witch wire goes in what? i have no clue
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
I got a sony xplod amp 1000 watt everything is connected good the ground wire is on a bare metal surface 12v wire good power fuse ALL wiring is as it should but there is no bass? the green light is on but...
Open your sub-woofer and check the continuity of your bass speaker. Chcek also the fuse of the sub-woofer amp...the fuse might be busted already.
How to fix a busted sub woofer it does it sound right
Usually, subwoofer repair is more expensive than purchasing a replacement sub. But if it is absolutely necessary, there are several speaker repair sites online. To try and repair it yourself could be more damage than good, depending on the issue.
-=Zzed=-
1helpful
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Subwoofer.......
Please check your model number, I can not find it on the JVC service website.
This is a powered sub-woofer I think. You need to have a thick black cord that connects the sub to the head unit. Then the satellite speakers get connected to the speaker jacks on the sub-woofer box. The sub-woofer should also be plugged into an A/C outlet on the wall.
The speaker outputs are labeled right there where you connect the speaker wires. You should see a red and black connector for each speaker and they are labeled "front right" "front left" "center" "rear right" "rear left".
If you do not have the thick black cord you need to connect the head unit with the sub-woofer, you can not use this system.
If you look at the head unit and give me the model number on it, I may be able to find the part you need. But I must have a good model number to work with, preferably from the head unit.
Dave
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
