Stops at post will not load nothing works code 7f shows in led window. means bad cable ide changed bios default reset still wll not show bios screen froze
Did you ever resolve?
This is the board with the external OC monitoring panel, right?! I owned this, too. I had a similar KV8 board from Soltek, as well--post codes, also. My Abit died several years ago.
The ABit's manual still exists online. According to the code, It's hanging on the onscreen logo--it says to switch to text. Here's the page describing your code: http://www.manualslib.com/manual/615/Abit-Amd-Athlon-Kv8-Pro.html?page=69#manual
If I remember correctly, that's not a serious error code--popped up often after new installs.
If it's a hard drive error--do you have the master/slave configuration jumpers correct? (Hard drive vs. Optical drive? Probably, you want the hard drive as master--optical as slave)
Is cable orientation (Pin 1--from PATA cable and at drive(s)/board) correct? Perhaps I remember now--maybe the BIOS can't get to the hard drive and OS.
Is your floppy light always illuminated (it shouldn't be)--is that cable installed correctly?
If your onboard hdd controller is dead--and, you worked with AGP over the years--you likely have a PCI card that will take its place. (If not, you may purchase that pretty easily. still.) Syba, Siig, Sabrent, StarTech, etc.
If your controller is OK, have you tried running a live i386 (32-bit) or AMD 64(64-bit) Linux disk or an old Bios upgrade/DOS floppy--to see if you get some type of OS posts? Is your proc 64-bit or 32-bit?: If I remember correctly, 754 CPUs generally were 64-bit--some were 32-bit, though (I still own one of those, too).
Did you clear your CMOS first (move the jumper for a few seconds and back)? Is the jumper correctly installed now?
Ah, the days of socket 754 (I never obtained Socket 939.....) Socket 754 still is a good value--you may obtain such a proc for about $5 on Ebay. (Used boards are a little pricey--considering.) I get the sense that 754 was the business board--939 was the gamer board.
Recently, I resurrected my old Shuttle Athlon XP board--considering its age, it holds up pretty well. Works fine with 32-bit Linux Debian distros. Dual-channel. Great OC board in its day. Currently, I have a 9800XL card in--soon, I'll put in a 3850 AGP....
SOURCE: KV8 Pro motherboard,athlon 64 3000
Post Codes in the back of the manual, download manual from the Abit Web Site
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=KV8+Pro&fMTYPE=Socket%20754&pPRODINFO=Specifications&fSEARCHTEXT=KV8%20Pro
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to Advanced Bios features press Enter you will see what the boot order is set to.
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
If you are unsure on what the boot order should be you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
This will set the boot order.
if you need more help with this or if i have misunderstood the problem
post a reply
hope this helps you
if you need more help with this post a reply
hope this helps
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test or replace all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard)) drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is
