Washing Machines Logo
Micky Fraser Posted on May 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does Miele w2515 makes loud banging noise when it is about to spin?
Washing machine makes a big loud banging noise when starting to spin. What is making these noises as the machine also moves a lot. Please help. It is a Miele w2515 model and is also around 6 years old
  • Micky Fraser May 23, 2014
    I have rechecked and is level. I have ordered new shock absorbers as i think they are flogged out. I will post again in two weeks once i replace them and let you know the outcome.
John Ray
Level 3:
  • Master 790 Answers
  • Posted on May 23, 2014
John Ray
Master
Level 3:
Answers
790
Questions
0
Helped
186478
Points
2180
See if you can level out the unit. Sound like the case is responding to un-even pressures.
5 Related Answers
David Shaub
  • 2994 Answers
  • Posted on Feb 02, 2009
SOURCE: Washing Machine Moves in Spin Cycle
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
Anonymous
  • 19 Answers
  • Posted on Nov 05, 2007
SOURCE: washing machine will not spin makes loud humming noise
motor coupling needs to be replaced
Anonymous
  • 188 Answers
  • Posted on Mar 10, 2009
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Anonymous
  • Posted on Mar 23, 2009
SOURCE: Indesit wil103 makes LOUD banging noise on spin cycle
The two dampers that fix to the outer drum casing have plastic bushes that can fall out. Check the floor under the machine, They are easy to replace just click in place.
nathan
  • 634 Answers
  • Posted on Apr 23, 2010
SOURCE: my washtub makes a lot of noise in the spin cycle
there are shocks inside the machine that damper the vibration, one or more has failed, they can be replaced if you are a good do it your self er, if u have to pay to fix it replace not worth the cost of repair. the repair requires taking off all the panels to access the inside. and check cost of dampers and compare to cost versus replacement
Loud banging noise Kenmore model # 41744102301
Hello,washing machine is mounted on two supports, if it is damaged first which is where the engine so both need to be replaced because they wear out. If you're just a little handy so you know it himself .Ak you order parts so precisely that type because they are different .
1helpful
My LG Intellowasher M-1480FHD has started making a loud banging noise on the final spin. It also wouldn't end the spin cycle at the end of the 30min wash
the banging noise while in the spin cycle will more than likey be worn shock absorbers and will need replacing.
4helpful
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
3helpful
FWT449GFS2 making loud banging noises during final spin cycle
lxr6232eqo making loud banging noises during final spin cycle
1helpful
2answers
Hi, our washing machine started making very loud banging and whining noise in the final spin cycle and the machine was shaking. We have taken off the back. The springs look ok. any suggestions?
Loud banging is usually an unbalanced load. whining noise is some times debris trapped in drain pump causing it to squeal like a fan belt on a car. Strings, threads and hoses tend to get wrapped under agitator and cause noise, too.
1helpful
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Top Washing Machines Experts
john h
