Question about HTC Touch Diamond Smartphone
My touch diamond was working perfectly......i didnt switch it on for a week as i had gone on vacation.after i came back n tried to swicth it on, it just wont work. no response. totally dead !! i put it for charging n even the white breathing light wont show......i tried soft n hard reset but to no avail..........i checked the battery n its fully charged.....PLZ HELP !!!!
Posted by meetsaji on
Anonymous
  • 79 Answers
Try cleaning battery contacts on phone and on battery with alcohol, maybe they oxidized
Posted on Jul 11, 2009
Bunn GRX-B won't heat and yes it is plugged in and vacation switch is on
You said "...turned vacation switch back on". In fact, it should be turned off for normal use.
If that's not the problem, and it's plugged into a GFCI outlet, press the RESET button (do not press the "test" button).
If still no joy, plug something else into that outlet to see if it works. If it doesn't, check the circuit breaker for that outllet.
Jul 14, 2014 | Bunn GRX-B
Usb port not working
has the unit done an upgrade if so use go back feature to 2 weeks ago and then try
Aug 17, 2013 | Toshiba Satellite C655D-S5084 Laptop
I set a cosecurty code in my htc p3700 but now when i enter that code it is not unlocked
Are you sure you enter correct code? IF yes maybe your phones need to be reset. Try to call your network provider and asking him about HTC Touch Diamond P3700 unlock code, don't forget to explain your situation and you need needs 1-2 weeks before you get that code and it takes a charge. Or you can try buy instant HTC unlock code from third party sites with lower price and more quick turnable.
May 09, 2011 | HTC Touch Diamond P3700 Cell Phone
I have a diamond video one touch and I have two concerns. Sometimes when I capture video there is a green bar at the bottom and sometimes not. Why Also I would like to take a snapshot from time to time,...
I, too, have the green bar at bottom problem occasionally. It only appears upon loading. When it does, I have been able to get rid of it by closing the program, then re-opening. Invariably, thus far, the green bar is gone upon second loading. Annoying, but the product has worked for me now for several weeks of heavy use.
Jan 06, 2011 | Diamond Multimedia ( VC500) Video Capture
HTC Touch Diamond screen alignment
Hi
with the one i have, i have to take the battery out leave it for ten minutes and try again- if that doesnt work do it again -
get someone to phone you - try and tap the settings.
If this doesnt work - try the above again -
after 3 /4 times you will be able to get into settings and realign......
cheers
Sep 11, 2009 | HTC Touch Diamond Smartphone
HTC Touch Diamond will vibrate, but won't ring on incoming calls
I just had this problem - and I have been messing with it for an hour.... but I finally fixed it - Try this - touch the speaker symbol on top (The system status window should pop-up) then touch the speaker symbol again (Now you should have two tabs - one for system and one for ring) Touch ring and slide it up. This worked for me.
Aug 02, 2009 | HTC Touch Diamond Smartphone
The touch screen doesn?t respond.
Call your carrier and Get insurance on the phone if you haven't already and then the insurance should cover it. They will insure the phone as long as it's working and turned on.
Then, a few days/weeks down the road, if it get's worse or completely stops working, you will be able to get it replaced. At this point, you may even get a Touch Pro in exchange for it when you do the insurance swap. They do charge $50-$100 deductable usually, but that's better than purchasing an entirely new phone when that one is no longer usable.
Also, here is a couple of sites that will definitely come in handy if you have an HTC Pocket PC:
http://www.ppcgeeks.com
http://www.ppckitchen.org
I hope this helps :)
By the way, I have two HTC Touch Pro and they both have issues. I think they are still trying to perfect these phones, but are far from it. The two sites I posted links to will help you get the most out of your Pocket PC until HTC and the Cellular Carriers get their stuff together with these phones...
-James
Jul 29, 2009 | HTC Touch Diamond Smartphone
HTC Touch Diamond Smartphone Logo
145 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Rob Woolcock
Rob Woolcock
Marvin
Marvin
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
