Removed all screws off the back will not come off unit
SOURCE: How do I remove the back panel from a samsung
Samsung LCD TVs has 12-16 screws that need to be removed before taking back off.
Dont forget the screws that hold the connection panel (SCART, HDMI, etc) and the bottom screws that hold the stand. These are screws i missed when i first opened my Samsung TV.
Good luck !
SOURCE: Samsung HP-T4264 will not autoprogram, locks up on
Reset to factory specifications by turning tv on, and then using the remote, hit power off, mute key, 1, 8, 2, and power on. Interval between key strokes is less than 3 seconds. When tv comes back on it shows Service Mode Display, key up to reset and press enter. Was able to autoprogram without any problems.
SOURCE: I have a Samsung HP-T4264 plasma tv with a badly
No way, Jose!
Those bastards manufactures are always making sure you won't be able to use parts from one model to the other. Especially-display! LCD panels could be rigged, but no plazma's. Sorry!
Sell it for parts to some repair shop and get yourself LCD or LED panel. Plazma is gone!
SOURCE: lCD TV
There is more than two screws holding the back cover on. I think it is more like 4 to 6. After you have removed all the screws you will nee a flat screw driver to help pry the two halves apart. Be careful the front of the cover has little snaps that help hold the two together.
SOURCE: my samsung hp-t4264 cuts off after a few minutes
I had the same problem. Fix it using the firmware update from Samsung Website. The customer support people are ****. They said it would caost be 500 to fix it.
