OKI Pacemark 3410 Matrix Printer Logo
A
Anonymous Posted on May 22, 2014
Okidata pacemark 3410 lock lever fell off
How to replace lock lever
4 Related Answers
A
Anonymous
  • Posted on Dec 10, 2007
SOURCE: OKI Pacemark 3410 Matrix Printer Error Writing to LPT1
A blinking alarm usually means an hardware error of some type, such as an obstruction on the printhead, or a bad motor or such.
When you have a blinking alarm light the other lights that are on will give you an error code that will tell you what the alarm means. You will need to look it up at Okidata.
Anonymous
  • Posted on Feb 05, 2008
SOURCE: oki pacemark 3410
Is the operating system Unix?
A
Anonymous
  • Posted on Jun 21, 2008
SOURCE: Okidata 3410 pacemark not printing correctly
Get your screwdriver and remove the new printhead. Now, reinsert the printhead contact board in the slot firmly, and MAINTAIN FIRM FORWARD PRESSURE ON THE ENTIRE PRINTHEAD ASSEMBLY WHILE YOU TIGHTEN THE SCREWS. Not too tight, but very firm pressure FORWARD. I don't know why, but this almost always works to get you same gap as before you changed printheads.
Anonymous
  • 8637 Answers
  • Posted on Jan 30, 2009
SOURCE: I have an Okidata Pacemark
Normal 0 This doesn’t help fix all printers because each situation is different and in most cases we don’t have enough information to determine the fix. So hope this will provide some help.
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
1helpful
Paper jams, upper feed roller does not turns.
Either a paper jam is keeping the roller from turning, or there is a problem with a belt or gear drive assembly. The unit will have to be inspected carefully, but if no jams are spotted, it will have to be disassembled to assess the problem. You can take it into a local computer repair shop, or contact OKI for support:
http://my.okidata.com/Home.nsf/Welcome?OpenFrameSet
Good luck, and hope this helps.
3answers
Print settings and network
is that printing compressed only if u use foxpro?
Is there a way to reset the printer if you want to stop a job midway when i print a report? OKI Pacemark 3410 Matrix
yes, clear all print jobs in the print queue on the PC.
The press "Stop" on the printer.
2. Turn the printer off for 1 minute the restart
3. Shut the PC down and restart.
This will clear the memory for both devices.
HOW DO I UNLATCH THE IDLER ROLLER LOCK?
Push the little white latch..you will notice a spring mechanism inside. Once you push on the latch the spring will move and release the lock.
Pacemark 3410 - printer shuts off after 30 seconds
Good chance the power supply is burned out. Located in the rear bottom of unit. You must remove the whole machine from case to get to it. Costs about $200.00 at any shop.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
I have an Okidata Pacemark 3410 and the alarm light is blinking and will not print. i turn on and off and the alarm light just comes back on.
OkiData Pacemark 3410
Resolution:
Using HP JetAdmin.
Select Device then Modify
Next until arriving at the Options screen.
Here is where we make the necessary changes to the parallel mode and handshaking
Click on the pull down arrow and change the parallel mode to Centronics and make sure handshaking is set to nACK and Busy then click Finish. Reboot the JetDirect box and cycle the power on the printer.
Oki pacemark 3410
3answers
Well, I had that problem once. What I did was that I used the printers cleaning tools. You can acces them by entering Printers in the ControlPanel. Then right click on your printer and select Settings. Look through there. Worked for me.
Top OKI Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
