Setting the Clock for All Systems Except AM-FM Stereo with Compact Disc Player
Press SET. Within five seconds, press and hold SEEK until the correct minute appears on the display. Press and hold SCAN until the correct hour appears on the display.
Setting the Clock for AM-FM Stereo with Compact Disc Player
Press SET. (The radio may be on or off.) Within five seconds, press the SEEK right or left arrow until the correct minute appears on the display. Press and hold SCAN until the correct hour appears on the display.
FM radio settings Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source. FM stereo option You can choose between stereo or mono reception when listening to FM radio. Mono may improve clarity where stereo signals are weak. To change between Stereo or Mono reception: 1. Press the Menu button. 2. Turn and press the Select dial to choose ‘Audio Setting’. 3. Select between ‘Stereo Allowed’ or ‘Forced Mono’. FM scan You can choose whether your Elan E3 automatically stops at the next available FM station or the next available FM station with a strong signal when scanning for an FM station. To change the FM scan setting: 1. Press the Menu button. 2. Turn and press the Select dial to choose ‘Scan Setting’. 3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source. Full scan You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and remove inactive ones. To carry out an autotune: 1. Press the Menu button. 2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be displayed during the autotune. When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the last station you were listening to is no longer available, your Elan E3 will tune into the first station in the alphabetical list. Manual tuning To manually check the signal strength of a known channel: 1. Press the Menu button. 2. Turn and press the Select dial to choose ‘Manual tune’. 3. Turn and press the Select dial to choose the channels.
https://docs.sony.com/release/ICFC218_US.pdf
Sony CorporationVarious types of alarms - radio and buzzer. Automatic time set - When you plug theclock in for the first time, the current time will be shown in the display.
1. Press and hold presets 2 & 3 for about 10 seconds until the first 3 digits of the display code are displayed.
2. Write the numbers down.
3. Press the AM/FM button, write down the next 3 numbers.
4. Call 1-800-537-5140, when asked, enter 620529, press the # button and enter the 6 digit code from the radio, you will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first 2 numbers, then press minute button and set the next two last numbers, press AM/FM button, SEC should be displayed, turn on radio.
To remove customers code, repeat step 5. you should see --- on radio face, the code is now out of the radio.
EDIT: Updated with new dealer code. FWIW, the old code was 202107
Make sure that this is NOT a "Sure Connect" version that has a very weak FM transmitter, but the older original model with a bland box. Make sure no earphone is plugged-in, then go to the menu and set the FM frequency and set the FM output level and you should be all set..
I didn't think this unit had an included FM transmitter - so I looked around for more info, and everything I've found indicates it does not.
It will however play audio via the built-in speaker or headphone jack. Use of a third party FM transmitter will allow playing audio (navigation, alerts, MP3 or audio books) when connected to the headphone jack and with both the FM transmitter and FM radio set to the same frequency.
The FM transmitter will work best when set to a frequency that is unused and has the least amount of interference from adjacent stations. Check by tuning the car radio across the FM band and note frequencies that have those qualities. Leave the radio on one of the clear frequencies and set the FM transmitter to the same displayed on the radio. You should try several to find the one that works best. Also, be aware that as you travel, you may enter an area where that frequency (or one close by) is in use by a broadcaster. This will require repeating the process as needed to reduce interference.
IF you have a cord plugged into the audio jack, if will TURN OFF your FM transmitter. You have to leave it unplugged for the FM transmitter to work. Go to MENU and make sure your FM station is set and that the FM OUTput signal is turned up. Write back if you need more help.
Thanks,
John
With the radio turned off and displaying the time, hold the MODE switch until the time display flashes (about 2 seconds). Release the MODE switch then quickly, use the TUN (up) to set hours, TUN (down) to set minutes.
