I cleared all paper but message is still there: 200.13 paper jam check cartridge
SOURCE: Clear paper jam message but no paper jam
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Check if
the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the
power.
2.Slide the cartridge carrier inside the
printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the
right-side of the cartridge carrier encoder strip
Note:
The
encoder strip is a plastic strip with small markings over its entire length.
The strip may appear to be translucent.
Reposition
the Encoder Strip
1. Remove the power cord from the printer.
2. Lift the scanner unit to expose the
inside, where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to
the middle of the printer.
4. Gently move the top part of the printer
belt to the right.
5. Using an index finger, gently push
encoder strip (Figure 1) down and then back up, to get it back into the slot
located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear,
and then forward, to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier
to the left, then to the right, to check the positioning of the encoder strip.
8. Once the encoder strip has been
re-seated, close the scanner lid.
9. Re-connect the power cord to the printer.
Ensure
the Paper Tray is Not Overfilled
Each
printer tray has a maximum capacity rating, and this rating is based on a
specific paper weight and or thickness. Consequently, situations might arise in
which the tray will not be able to accommodate the maximum number of sheets
listed in the printer specifications. Verify that the paper is not packed too
tightly in the paper tray.
Adjust
the Printer Paper Guides
Adjust
the paper guides to fit the size paper being used .The guides should be close
(1/16" or less) to the paper without touching, so that the paper stays
properly aligned without continually rubbing the guides.
Locate
and Remove Any Obstructions Inside the Printer and Input Tray
1. Open the front cover and make sure the
kickstand (if there is one) is engaged.
2. Locate and remove any obstructions within
the printer, such as paper pieces, staples, tape, or other objects.
3. Close the cover.
4. Remove all paper from the input tray.
5. Inspect the input tray for any
obstructions.\
6. Remove any visible obstructions.
7. Reinsert the paper.
Clean the
paper feed roller on the printer.
1. Power down the printer and disconnect the
power cord.
2. Remove all paper from the input tray.
3. Wipe the roller gently with a damp cloth.
SOURCE: not working see bottom
Check your entire feed to make sure there is NO paper jams. Sometimes even the smallest little piece of paper can get jammed up and can e hard to see.
You can also check your manual for diagnostic mode and alignment print page.
SOURCE: jam msg will not clear ? no paper in path?
when you removed the paper, a small piece might still be stuck somewhere or the sensor might have remained in the on position.
SOURCE: Clear Paper Jam message on my Dell 948 nAll in One
press cancel button,, for 30 seconds, it will reset, either, press, on/ off button once.
SOURCE: 1320c Dell Printer has blinking orange error
If the light is flashing, it might not be the PHD, but you might be having a problem with the PDL emulation. Just go the control panel, right click the Dell printer. Select printer properties, not properties. Go to the advanced tab and check print directly to printer instead of spool print documents. This should work.
