Question about Sharp AR-5516s
Maintenance indicator what's the code?
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
How to fix code 17?
The site do the maintenance or do some upgrade
Yahoo error code 17 commonly appears during system maintenance. This can go on for minutes or more than a day. Keep checking your email through normal login procedures. Check the login regularly as there is no indication when Yahoo email will be up and working again.
Thanks for using Fixya
Jun 02, 2011 | Yahoo Mail
What do a wrenchwarning light mean
this usually indicates service engine soon light(possible code in computer)or it is a maintenance service light indicating a maintenance should be done to the car.
Mar 18, 2011 | 2006 Ford Five Hundred
How do I find out how many pages are on the current drum in my Brother 2820 machine
You must enter in maintenance mode:
Press the Menu/Set and Start keys. Next press the key four times to make the machine enter
the maintenance mode, or turn on the machine while pressing the menu/set key.
The machine beeps for approx. one second and displays "MAINTENANCE " on the LCD,
indicating that it is placed in the initial stage of the maintenance mode, a mode in which the
machine is ready to accept entry from the keys.
Display of the Equipment's Log Information (Function code 80)
Function
The equipment may display its log information on the LCD.
Operating Procedure
(1) Press the 8 and 0 keys in this order in the initial stage of the maintenance mode.
The USB serial number appears on the LCD.
(2) Press the Start key. Each time the Start key is pressed, one of the following log
information items appears on the LCD in the order given below.
1) Jam count, indicating how many times a paper jam has been occurred
2) Page count, indicating how many pages the photosensitive drum has been printed
3) Total page count, indicating how many pages the equipment has been printed since
produced
4) Drum count, indicating how many times the photosensitive drum has been rotated
5) Drum change count, indicating how many times drum replacement has been made
6) Toner change count, indicating how many times toner replacement has been made
7) Copy page count, indicating how many copies have been made
8) PC print page count, indicating how many pages the equipment has been printed as
an output device of the connected PC
9) FAX page count, indicating how many received FAX pages have been printed
10) Error code of the most recent machine error *1
11) Error code of the most recent communications error *2
12) ADF jam count, indicating how many times a document jam has been occurred
13) ADF page count, indicating how many documents have been fed
(3) To stop this operation and return to the equipment to the initial stage of the maintenance
mode, press the Stop/Exit key
To exit maintenance mode press 99
Mar 07, 2011 | Brother IntelliFax-2820 Laser Fax
How do i reset oil change indicator
  1. Turn the ignition switch to the ON (II) position.
  2. Press the Select/Reset knob repeatedly until the engine oil life indicator is displayed.
  3. Press the Select/Reset knob for more than 10 seconds. The engine oil life indicator and the maintenance item code(s) will blink.
  4. Press the Select/Reset knob for more than 5 seconds. The maintenance items code(s) will disappear, and the engine oil life will reset to 1OO.
Dec 27, 2010 | 2006 Honda Accord
Display the Call service C6400 code
C6400 is a fixing unit error. You may need a new fixing unit but most of the time it can be reset in maintenance mode.
Use the following steps to enter the maintence mode, once there follow the steps for maintence mode 163 (reset fuser error). Do not do anything else in the maintenance mode area because you could damage your machine
Press the system menu/counter key.
Select Service setting using the up/down cursor keys.
While pressing the start key and the # key, press the enter key.
Select Maintenance mode using the up/down cursor keys.
Press the enter key.
Enter the maintenance item number (163) using the up/down keys.
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020, C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Turning power switch off and back on
Resetting the fusing problem data
Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
Completion
Turning power switch off and back on.
I hope this is helpful,
Shawn
Dec 22, 2010 | Kyocera Copystar CS-1820 Black and White...
The maintenance check engine light change to yellow from green first.. Now turning into red
The maintenance light by the odometer is just a 10,000 mile indicator. You can reset it by pushing the tip of your key on the reset slot in the speedometer, which is exactly what a mechanic will do after performing the appropriate maintenance for the age of the car.
How many miles are on the car? Your owners manual will have a table in the back that lists what work should be done and when. If you do all your own work, then just reset your maintenance indicator and go on your merry way.
If not, then you should take it to a mechanic for the service checks, and have them reset the indicator.
If your Check Engine light is also lighting up, then you should take it to a mechanic or an Auto Parts store (checker/autozone/pep-boys,etc) and they can read the trouble code for free. On a 1996 Accord, the connector is behind the ashtray in the center console.
Dec 01, 2009 | 1996 Honda Accord
Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Feb 04, 2009 | Sharp MX-2700N Color Copier
I changed my oil on my LX and the change oil warning is not reset
RESETTING THE ENGINE OIL LIFE INDICATOR
On LX and EX models
If maintenance is done by someone other than your dealer, reset the maintenance minder as follows:
1. Turn the ignition switch to ON ( II ).
2. Press the SELECT/RESET knob until the engine oil life indicator
is displayed.
3. Press the SELECT/RESET knob for about 10 seconds. The engine oil life indicator and the maintenance item code (s) will blink.
4. Press the SELECT/RESET knob for more than 5 seconds. The maintenance items code (s) will disappear, and the engine oil life indicator will reset to "100".
Jan 01, 2009 | 2004 Honda Odyssey
Sharp AR-5516s Logo
66 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
